changing fuel filters on my Airdog 150
Old Dec 29, 2013 | 03:59 PM
ROCKITV8's Avatar
Default changing fuel filters on my Airdog 150
I have a 2006 with the airdog 150 when changing them I started by draining the H2O sep. first....seems like its draining the whole tank after 5 gallons later I shut it off. should I drain and change when he truck is empty ???? I dont want to pull the filters offand fuel go everywhere ??? Thanks
Old Dec 29, 2013 | 04:35 PM
01trailerpuller's Avatar
You are creating a siphon effect somehow. I would suggest cracking the h20 valve then breaking loose the filter. Should stop the flow of fuel from the tank. Also I would suggest using Donaldson filters. They are cheaper, last twice as long and are 2 micron instead of the 5 micron from airdog.
Old Dec 29, 2013 | 05:26 PM
ROCKITV8's Avatar
I am actually using Fleetgaurd filters Which are 2 micron also on my Airdog got both for $31I will try what you suggested. Thank You
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
