fuel pump going out?
Old Dec 28, 2013 | 02:27 PM
bigry's Avatar
Default fuel pump going out?
The other day I was towing my trailer home and my truck started to lack power then ran real rough. I pulled off the freeway and shut it down then it wouldnt restart. Towed it home and the next morning it fired up but ran really rough. I changed fuel filters and icp sensor with new pigtail and that didnt help. I borrowed my buddys snapon scanner and with the fuel pump test the pump sounds really gravely and it takes a while to fill the upper filter housing. The fli% is 17.3 and the fli v is .30. Does this mean anything? my truck is an 03 6.0 egr delete with 144,000 on it thanks for any help
Old Jan 10, 2014 | 12:05 PM
sickopstrokefan's Avatar
Sounds like u solved ur own prob! I would say yes. Fuel pump.
Old Jan 10, 2014 | 04:02 PM
bigry's Avatar
The fuel pump helped but took out injectors 1,3,5,7
Old Jan 10, 2014 | 06:55 PM
bobfbigman's Avatar
if you got codes for those injectors then I would look at having the FICM rebuilt, the odds of all the injectors on pass side failing at same time are slim, even if the pump was taking a dump. injector codes for a bank at a time indicates a faulty FICM
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
HardLuck
Jun 24, 2015 08:04 AM
bud0994
9
Jun 8, 2015 06:15 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Gm3500
May 7, 2015 11:01 AM
