High Beams/ Washer Fluid
Old Apr 17, 2008 | 12:22 AM
dalton06's Avatar
Default High Beams/ Washer Fluid
My truck is losing it; when I try to turn my brights on or off my washer fluid squirts out like I pushed the lever in but I'm just pulling back. Any clue?
Old Apr 20, 2008 | 08:30 AM
twoforme2's Avatar
Have you recently had things taken apart...maybe a couple wires pinched that are shorted to each other...outside of that I would suspect the switch itself. You should be able to unplug that and check it with a meter.
Old Apr 22, 2008 | 09:55 PM
solarwarp's Avatar
I sometimes have the same problem, mine usually does that when I'm drunk.
Old Apr 24, 2008 | 09:57 PM
dalton06's Avatar
dont know if I could control the wipers and lights when im drunk. so I just risk the truck and hand the keys over
Old May 1, 2008 | 07:41 PM
lilfroger's Avatar
the high / low washer is all part of the same switch
http://www.dodge.com/bodybuilder/200...8w53wipers.pdf
wonder if your ground isn't bad or your switch is going out
Old May 1, 2008 | 07:44 PM
dalton06's Avatar
it has quit doing it at the moment. I haven't messed with any wires or nothing.
Old Jan 26, 2009 | 12:43 AM
darkhorse06's Avatar
replave the multi-function switch. It's a simple swap. Take the cover off the column, remove to screws, two wire connections, and swap it out. Very simple. Part from dodge cost about 70 bucks, just replaced mine a month ago. Had the same symptoms, changed it, no problems since. One tip, a small pair of channel lock pliers and a short phillips tip for a drill is a must...
hope it helps...
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
4x4kingx889
Sep 13, 2015 09:55 AM
Jet A Fuel
Aug 3, 2015 10:45 AM
robbyS
Apr 16, 2015 02:22 PM
gvanevans
Dec 26, 2014 04:39 PM
