Fuel pressure
Old Dec 27, 2013 | 09:37 AM
Volvomec's Avatar
Default Fuel pressure
hello all just installed new gauges & don't like what I found. fuel press @ 10 psi @ idle & 7psi @WOT. how long do think I can go. money is tight. think I could go with Holley blue & push fuel through stock pump or delete stocker. also I plumed into top of fuel canister in 1/8 plug. just changed fuel filter. think that would make a difference????? thanks
Anybody???????????
Old Dec 27, 2013 | 01:19 PM
jigabop's Avatar
holley blue is a waste of money.
it will work but not for long.
the seals inside the blue pumps are not rated for diesel and they will fail very quickly as the fuel will eat through the seals and make the pump start leaking fuel. eventually fuel will leak into the motor of the pump itself and take the pump out all together.
Old Dec 27, 2013 | 01:46 PM
BarryB's Avatar
I'd say, If its a stock lift pump, thats probably all you gunna get. Id also say, you can drive the truck just keep an eye on the pressure and don't try hot rodding it. keep it stock. BUT definitely be saving for a good, airdog, fass lift pump. 400-600 range depending on what you get. Or save even more and get a new IP and lift pump combo for what I have seen 1300 1400 range. Thats my .02
almost for got, you can get a ddrp from Fass, that'll boost your pressure just a bit. but won't handle any power adders.
Old Dec 27, 2013 | 11:55 PM
OlRed2ndGen's Avatar
almost for got, you can get a ddrp from Fass, that'll boost your pressure just a bit. but won't handle any power adders.[/QUOTE]
I have a fass drp, 3/4 fuel lines, mild built trans, and pillar gauges.. Would I be okay too run 125 hp Edge injectors and a Edge Comp Box on my truck? Or bad idea? Most people said I would be fine. Whats your opinion?
Old Dec 28, 2013 | 05:48 PM
rrimpa's Avatar
from what I have seen spend the money on a good lift pump and then worry about injectors and comp. a good lift pump will save you a lot of headaches later
Old Dec 30, 2013 | 02:24 PM
jigabop's Avatar
75gph pump will not keep up with mods...even FASS will tell you this.
95GPH or better if you want to start adding performance mods.
my truck has a 150GPH lift pump on it with a 1/2" draw straw, and 1/2" fuel lines from the tank all the way to the vp44.
Old Dec 30, 2013 | 11:16 PM
So I need to buy a good lift pump before anything?
Old Jan 1, 2014 | 03:43 PM
BarryB's Avatar
yeap
Old Jan 2, 2014 | 03:30 PM
IbeCummins02's Avatar
ha ha I bought an 02 cummins last summer... less then a month and I put a fass titanium lift sump. heard many a horror stories of vp44 failure due to lift sumps, don't let any dodge dealers try to get you to do the mopar update... its garbage go fass or airdog.
Old Jan 4, 2014 | 08:20 AM
Precision's Avatar
I didn't listen and I ended up replacing my vp and lift pump a month after I bought the truck with 148k miles on it. I thought money was tight too. It was tighter at the tune of $1500 for new stuff. Now I pay attention when someone gives a warning, I also keep money saved up for repairs. You would be wiser and richer to do the same.
Dbleo351
Nov 20, 2016 09:34 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
cummins Pride
Oct 6, 2014 11:28 AM
