delayed shift on rebuilt transmission
Old Dec 23, 2013 | 06:48 PM
Cumminsambitionist's Avatar
Default delayed shift on rebuilt transmission
Hi i recently had my transmission rebuilt and then needed a new lift pump and injection pump, all thats been replaced and under warranty, but since my truck has delayed shifts. when the truck was new it would shift thru the gears with no hesitation now it seems like it doesnt want to shift until you let off the throttle. any ideas, thanks
Old Dec 23, 2013 | 11:58 PM
lauber_03's Avatar
what all was done to the tranny? check the fluid also.
Old Dec 24, 2013 | 05:05 AM
detroitdiesel idi's Avatar
Possible valve sticking in valve body
Old Dec 26, 2013 | 01:32 PM
It has a new assembly kit, filter, kickdown band, rebuilt torque convertor, overdrive snap ring, sun gear, spring 3-4 accumulator, manual valve, pressure regulator, governer pressure sensor, overdrive solenoid, pressure solenoid, low drag bearing kits, governor bore plug. so far from what i have read, yes it could be a valve body problem, or a tv cable adjustment. With all that crap replaced you'd think this thing would be brand new by now.
AKDodge
May 14, 2015 12:52 PM
02Stain
Feb 17, 2015 10:21 PM
SixSpeed
Jan 11, 2015 01:41 AM
Alfdude1
Jan 9, 2015 01:19 AM
Trevlar11
Dec 11, 2014 03:30 PM
