ENGINE/TRANS SURGE AT 55MPG
Old Dec 23, 2013 | 03:31 AM
fmx23's Avatar
Default ENGINE/TRANS SURGE AT 55MPG
2000 DODGE 2500 24VALVE
JUST YESTERDAY THE ENGINE IS STARTING TO SURGE AT 55MPH WHILE CRUSING. WHEN DRIVING THE RPMS JUMP FROM 1300 TO ABOUT 1800 EVERY SECOND OR SO AND YOU CAN DEFINETLY FEEL IT INSIDE AS IT ROCKS YOU BACK AND FORWARD. IT FEELS LIKE THE TRUCK IS TRYING TO DOWNSHIFT BUT IT DOSENT FULLY AND THE RPMS JUMP BACK UP TO GET BACK UP TO SPEED. NOW WHEN YOU INCREASE THE SPEED TO 60MPH AND ABOVE IT SEEMS TO GO AWAY.
TRUCK HAS EDGE EZ INSTALLED,NEW INJECTION AND LIFT PUMP, ONLY HAVE ONE CODE FOR A CRANKSHAFT POSITION SENSOR, NEW FUEL FILTER AND ALL THAT. NOW THE TRUCK HAS BEEN RUNNING GREAT WITH THE EDGE INSTALLED BUT IT SEEMS LIKE ITS A COMMON PROBLEM WITH OR WITHOUT A CHIP INSTALLED.
ANYBODY OUT THERE KNOW WHATS WRONG
title is supposed to say engine/trans surge at 55mph. damn auto spell
Old Dec 23, 2013 | 09:19 AM
Bryce's Avatar
Sounds like your torque converter is going in and out of lock up. It's a common problem caused by the alternator interfering with the apps signal to the PCM. You can try wrapping the wires that run by the alt with foil which works for some folks but the only thing that worked for me was an apps noise isolator
Old Dec 23, 2013 | 02:23 PM
fmx23's Avatar
DOES IT MAKE A DIFFERENCE IF the truck works WORKS FINE WITH THE OVERDRIVE OFF AT 55MPH. OR IS IT STILL GETTING INTERFERENCE FROM SOMEWHERE
Old Dec 24, 2013 | 12:38 AM
Pclem's Avatar
Get a new speed sensor. 25$ at auto zone. My truck did the same thing. Swapped it out and have had zero issues. This was just a couple months ago too.
stump
5.9L CR Performance
Jun 11, 2015 09:52 PM
swartile
May 8, 2015 01:03 PM
rrough96
Feb 21, 2015 11:26 AM
99stackedpowerstroke
Jan 28, 2015 08:26 PM
Mc Merc
Dec 17, 2014 02:24 PM
