Eliminator Fuel System For Sale Only $200 SHIPPED !
Old Apr 16, 2008 | 04:59 PM
DB Admin's Avatar
Banned
Default Eliminator Fuel System For Sale Only $200 SHIPPED !
$599.00 new has less than 10K miles on it ,
Adjustable Fuel Pressure that dont drop when you get on it
Should have everything you need to hook it up minus a few fittings and maybe some more fuel line
THIS KIT UTILIZES A SPECIALLY DESIGNED PUMP, THESE ARE FULLY OPERATIONAL TESTED PRIOR TO SHIPPING AVERAGE CURRENT DRAW IS 5 amps @14.7 VOLTS @ 20 P.S.I. THEY FEATURE A LARGE GEROTOR. IT IS A VERY CAPABLE PUMP. APPROVED PUMPS WILL GENERATE OVER 50 P.S.I. APPROVED FOR S15 FUEL. IT FLOWS AN IMPRESSIVE 150 G.P.H. AT 9 P.S.I. WE CNC MANUFACTURE THE PUMP HOUSING AND FILTER BASE. THE PUMP ASSEMBLY IS CONFIGURED FOR EASY MOUNTING AND FILTER LOCATING. WE ADD ALL THE NECESSARY COMPONENTS TO MAKE THIS THE COMPLETE SYSTEM AS SHOWN. DURAMAX AND COMMON RAIL CUMMINS APPLICATIONS, WILL ALSO INCLUDE THE NECESSARY TUBING AND FITTINGS, FOR FUEL PRESSURE INCREASES UNDER BOOST OUR EXCLUSIVE RAILBOOST* FEATURE . THE 05 UP COMMON RAIL KIT INCLUDES THE SIPHON/DRAW TUBE FOR UNRESTRICTED FLOW. ALSO AVAILABLE SEPARATELY. THE FUEL RETURN REGULATOR, ALLOWS THE PUMP TO OPERATE AT DECREASED LOAD, YET REFERENCES BOOST ON SOME APPLICATIONS FOR INCREASED POWER ON DEMAND. THE DESIGN ALSO ALLOWS FOR INTIAL PRESSURE SETTINGS UP TO 20 + P.S.I. THE RETURN LINE WHEN MOUNTED UPWARD ALSO PROVIDES AN EXIT FOR AIR IN THE SYSTEM. YES IT IS SELF PRIMING. IT TAKES ABOUT 10 SECONDS TO FULLY PRIME THE SYSTEM. WE HAVE BEEN RUNNING AND SELLING THIS SETUP, FOR A OVER A YEAR. WE HAVE HAD VERY FEW ISSUES. THE SYSTEM HAS SUPPORTED IN EXCESS OF 800 H.P. ON DIESEL FUEL ALONE. THE FILTER INCORPORATES A STANDPIPE AND WATER SEPARATOR. IT WILL HANDLE 150 P.S.I. AND HAS A LONG LIFE. IT FILTERS TO 6 MICRONS. 3 AND 2 MICRON FILTERS ARE AVAILABLE, AS WELL AS THE MEGA FILTER KIT. OUR STANDARD FUEL LINE SIZE IS 3/8", ON 98.5 - 04 CUMMINS, 1/2" IS STANDARD FOR 05 UP CUMMINS AND DURAMAX. A COMPLETE ELECTRICAL HARNESS IS PROVIDED. IT INCORPORATES A HIGH CURRENT RELAY AND INLINE FUSE FOR CIRCUIT PROTECTION, AS WELL AS PUMP TRIGGER. THIS IS THE BEST LOOKING AND PERFORMING SYSTEM AROUND.
  • In-House - Meets Our Strict Standards
  • Fuel PSI Fully Adjustable with bypass/return setup
  • Eliminates all the restrictive stock banjo's
  • Tested at high altitudes in sub zero conditions, with no issues
  • Super suction pump and high flow rate
  • No Springs , Belts , Plungers to Change EVER
  • Will run Constant 4.5 - 22 psi
  • Draws only 5 amps @ 20 psi and 14.7 volts.
  • Boost Referenced On CR Applications Only
  • Gerotor pump
  • 6 micron filtration
  • Flows over 200 GPH
  • Capable of over 70 PSI
  • Has fueled over 800 hp on #2 alone.
  • Billet Aluminum Construction
  • Equipped with 3/8" or 1/2" Fuel Lines 1/2" will need the siphon tube
  • 500,000 Mile Pump
Heres Whats left after i installed a different system for other personal reasons
Old Apr 16, 2008 | 05:44 PM
DB Admin's Avatar
Banned
SOLD
Old Apr 16, 2008 | 06:11 PM
jstange2's Avatar
dangit
Old Apr 17, 2008 | 11:24 AM
DB Admin's Avatar
Banned
shipped
