1996 Chevy 6.5L Turbo - Won't Crank
Old Dec 22, 2013 | 02:06 PM
BrianSmith540's Avatar
Default 1996 Chevy 6.5L Turbo - Won't Crank
I'm back with a cranking problem. I turn the key and get nothing. I don't even get the sound of the lift pump going....
- Battery test - good, both are at 12.5v
- Neutral Safety Switch test - good
- Relay test on position 85 - good
- Relay test on position 87 - not good. Cannot get power on test lamp or DVOM
- Turn headlights on and dome light, turn ignition and get a little dimming if any.
- Turn radio, heater fan, and turn signal on and turn ignition. Radio and heater fan go off immediately.
Any thoughts really appreciated.
Old Dec 22, 2013 | 02:25 PM
Mayhem's Avatar
Check and clean all grounds mainly the one on rear passengers side head
Old Dec 22, 2013 | 04:19 PM
Default Stay grounded
Mayhem,
Sometimes the easy fix sounds too good to be true. Checking grounds.......
Old Dec 23, 2013 | 07:40 AM
racer55's Avatar
Need the wiring diagram of the relay posted-no idea what circuits the pins mentioned are related to?
Old Dec 23, 2013 | 07:35 PM
Default Wiring Diagram
Racer55
Two links; here is the link to the wiring diagram.
https://encrypted-tbn2.gstatic.com/i...x1vqla-4RMVS3A
Here is link for picture of fuel pump relay
Google Image Result for http://i1.ytimg.com/vi/McnXLcJNVfI/maxresdefault.jpg
Old Dec 25, 2013 | 07:10 AM
racer55's Avatar
Unfortunatly the 2 pictures don't jive with each other.
I need a picture of the relay that has a diagram on the side or face that looks like the wiring diagram showing the terminal #'s not letters,then I can figure out how they have it wired.
Old Dec 25, 2013 | 04:03 PM
Racer55
Hope this is what you are looking for:
http://sid2day.com/images-BC/Truck/1...Pump_Relay.jpg
Still no fix....
post 87 on fuel relay from what I can find is supposed to go "hot" for a couple of seconds when cranking the engine. I get a constant 0.1 on the DVOM when ignition is "on"
My next fix per Chilton manual is to check the bulkhead fusible link and ignition cable.
I know I have two fusible links to the glow plugs. Does anyone know where I can find the bulkhead fusible link and do I need to disassemble steering housing to check the ignition cables?
This is perplexing so any help would be appreciated.
Cleaned and tightened grounds still nothing.
Last edited by BrianSmith540; Dec 25, 2013 at 04:03 PM. Reason: Automerged Doublepost
Old Dec 25, 2013 | 09:34 PM
dallonj's Avatar
Change the starter
Old Dec 25, 2013 | 11:18 PM
Irish_Alley's Avatar
Originally Posted by dallonj
Change the starter
when we started to work on our 6.5 the lift pump wouldnt work. replaced started and it started to work again. idk what it has to do with it or even if it was a coincidence
Old Dec 26, 2013 | 08:26 AM
racer55's Avatar
There are fusible links on the heavy terminal of the starter.
That relay is difficult to understand-never saw one drawn that way before.
If terminal 30 also has no power,try this:
If you have the truck safely parked,try quickly jumping terminal 85 and 30 of the relay socket and see if the starter engages.
If so you need to solve the power problem on terminal 87.
If terminal 30 is always hot try jumping 30 and 87-if the starter engages the relay is bad provided that terminal 86 has a good ground.
