Blowing tops off battery
Old Dec 19, 2013 | 08:21 AM
ROME's Avatar
Default Blowing tops off battery
I keep blowing my passenger side battery. I have changed the altnator and both battery's. I'm afraid it might b the tipm. Does anyone have any other suggestions that could solve my problem?
Old Dec 19, 2013 | 09:17 AM
chrisa1995's Avatar
TIPM? How many batteries have you went through? how much voltage is going to them while running? How long is the battery lasting? 2 minutes, 2 weeks, 2 months??
Old Dec 19, 2013 | 11:15 AM
dangerous1965's Avatar
Charging is controlled by the ECM. Be sure all your wires and grounds are clean and tight!
What voltage are you seeing while running?
Old Dec 19, 2013 | 06:51 PM
ROME's Avatar
Im in the middle of changing all my cables and Battery Terminals. The ones that are on my truck are nasty and lose. This battery lasted 4 months. I cant run the truck to check the volts because the positive terminal burned off when i came out to go to work this morning. will check the volts when i get all back together.
Totally Integrated Power Module (TIPM)
Sorry I should have said my truck is a 2006 3500 dodge
All done seems to be charging and the battery isnt getting hot. Thanks for your guys help
Flash123
Ford Powerstroke 08-10 6.4L
Jun 25, 2015 10:19 PM
misstiffany
Mar 21, 2015 09:43 AM
carid
Diesel Bombers Sponsors
Dec 4, 2014 05:06 AM
Kentonjl
Sep 30, 2014 07:22 AM
Rebel_redneck
Sep 29, 2014 11:05 AM
