2004 5.9 cummins 24v white smoke at idle
Old Dec 17, 2013 | 02:24 PM
dillonb123's Avatar
Default 2004 5.9 cummins 24v white smoke at idle
My truck recently started white smoking at idle stops when I am driving doesn't run rough or idle rough no power lose. Seems like it started right after I get on the stop at a light. What could this be?
Old Dec 18, 2013 | 10:55 AM
cerberus60's Avatar
White smoke is almost always injectors. Time for some testing to see what their status is.
Old Dec 19, 2013 | 08:17 PM
dillonb123's Avatar
Normal for 4 of them to all the sudden act up? Only 120k on truck
Old Dec 19, 2013 | 08:34 PM
cerberus60's Avatar
If they go bad they can all go bad or just some. Mileage is almost no considering if a bad batch of fuel was run thru them. 120k is usual in some places due to fuel quality.
Old Dec 21, 2013 | 04:37 PM
jkidd's Avatar
we see the 2003-2004 305HP lasting around 160k, 04.5-07 325hp about 120k. the 325hp has 1 more injection event and consequently have more wear in the injectors.
Old Jan 10, 2014 | 06:15 PM
dillonb123's Avatar
okay thanks. I have another question will 2004.5 nozzles work with my injector silonoids its a 2004
Old Jan 10, 2014 | 06:59 PM
cerberus60's Avatar
That is not a good idea, does not bode well for the piston. Stay with the 03-04 nozzles.
Old Jan 14, 2014 | 11:02 AM
steved's Avatar
What does the "smoke" smell like? Fuel? Coolant?
White smoke is also a sign of coolant getting into the stream...
Old Jan 26, 2014 | 12:40 PM
Cjasso78's Avatar
Steved is right, I have seen a few bad head gaskets result in white smoke. Might want to do a little more checking before you drop cash on injectors.
Old Jan 26, 2014 | 02:46 PM
cerickson's Avatar
I just replaced my injectors in the wife's truck. Had 3 going bad. It's only got 103,000 on it.
mattshow123
14
Mar 12, 2018 01:41 PM
JoeyMiR
9
Feb 3, 2018 10:05 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
ryank 199
May 14, 2015 06:41 PM
#cummapart
May 5, 2015 12:54 PM
