99 24v dually spewed all its trans fluid
Old Dec 17, 2013 | 10:27 AM
c4mo's Avatar
Default 99 24v dually spewed all its trans fluid
Yesterday i went to start my 1999 3500 dually with 24v and 47re trans. Being cold outside i let it warm up a little bit. I moved it up about 15 feet when i noticed it was pouring out transmission fluid. The leak looks to be coming from a cylinder shaped canister mounted on the side of the engine on the passenger side behind the turbo close to the rear of the engine. These lines looks to go to the side of the transmission and then to the trans cooler in front of the engine. I'm wondering the correct name for the part on the canister mounted on the side and possibly when to get replacement fittings or seals for it. I would try to search for it, but again dont know the name. Thanks.
Old Dec 17, 2013 | 03:12 PM
illinoisfox's Avatar
THat is the oil to coolant cooler.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
PA 24valve
Aug 31, 2015 07:39 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
DieselDan_5.9
Jul 30, 2015 07:05 AM
Bigredpowerstroke
Dec 19, 2014 05:18 PM
