2 questions
Old Dec 16, 2013 | 11:16 PM
jburger76's Avatar
Default 2 questions
First one. ...my boost pressure says 20 psi running and 14 with the engine off. Is this also the map sensor??
2nd has anyone tried to change 6th gear for a higher ratio for better mpgs??
Thanks. Jeremy
Old Dec 17, 2013 | 01:00 PM
cerberus60's Avatar
If you are reading thru the data port then yes that comes from the MAP sensor.
Probably can switch to the higher ration if you can get the correct parts. It is just 6th gear differneces. Will need counter shaft and main shaft gears both of they are removable.
Old Dec 31, 2013 | 11:58 PM
keepitreal's Avatar
G.V. Overdive? Kinda spendy but what isn't?
Mar 20, 2015 08:20 AM
VanGuy
Feb 3, 2015 12:19 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
