2001 dodge diesel
Old Dec 17, 2013 | 09:05 AM
That trough guy's Avatar
Default 2001 dodge diesel
Hi I'm new to this forum. I have a 2001 cummins
Recently I rebuilt tranny. It appears lock up won't lock up. Shop has replaced speed sensors, and Tcc solenoid 2 times now. And he insists its not the torque. I've check all the grounds I can find. I've put foil around alt wire and tied it up out of the way. Still not working correct. Rpm is up around 2300 used to be 1750. It only does this when I'm pulling my 14' enclosed trailer and only since tranny was rebuilt.
I might add I've been driving it like this since oct. and it hasn't gotten any worse. It's just screaming and driving me nuts. Very hard on fuel as well. Anyone might know anything at all.
Last edited by That trough guy; Dec 17, 2013 at 09:05 AM. Reason: Automerged Doublepost
Old Dec 17, 2013 | 03:42 PM
lauber_03's Avatar
sounds more like you lost overdrive.
Old Dec 17, 2013 | 04:10 PM
Thanks for your reply. This really stumps me cause when I click the overdrive off it still jumps up in rpm like up to 2800
Old Dec 17, 2013 | 05:41 PM
lauber_03's Avatar
no overdrive and no lock up if its that high of rpms. what speed?
Old Dec 17, 2013 | 06:54 PM
Around 2800
Sorry that was 2800 at 100km or 60 mph. This only happens while I'm towing. When not towing the shift 3-4 and overdrive and lock up are real slow to shift.
Last edited by That trough guy; Dec 17, 2013 at 06:54 PM. Reason: Automerged Doublepost
Old Dec 17, 2013 | 06:59 PM
illinoisfox's Avatar
You need to put a gauge on the OD port to see what pressure it has. I have seen them pop the seal on the OD piston and do what you are experiencing.
Old Dec 17, 2013 | 07:17 PM
Wow really. Should most tranny shops be able to do this.
Thanks by the way. I'll see if I can get him to check that.
Old Dec 21, 2013 | 03:14 PM
Rooster24v's Avatar
also if your brakes are activated, this will kick the tranny out of lock up... dunno if it will help any but its an idea.
Old Dec 21, 2013 | 10:20 PM
Default Hey Rooster24
I just had a friend look at it this morning, he scanned it and came up with governor pressure is lower than what is preferred. And lock up seems to be not engaging fully. When I tap the breaks with foot on acc. Pedal tach jumps only about 25-30 rpm. If anyone might gave some insight on this subject please help me. I'm hoping I don't have to redo tranny
Old Sep 26, 2017 | 05:49 PM
odnob's Avatar
I have the same problem, took it to the tranny shop and they cannot find the problem other than suggest the harmonic balancer outter "ring" might have become a bit out of round over the many miles. (387,000). Tried the aluminum foil, cleaned the grime from the harmonic balancer. This did not cure the problem so I am still on the hunt.
Suggestions?
