New gauges
Put in new glow shift gauges in 01 3500.
Boost, EGT, fuel pressure
Boost is reading 22 max
EGT is reading 400 to 1000 and responds fast to throttle.
Fuel pressure 9 at idle 4 at wot.
Truck has in tank fuel pump and 4" exhaust with magma flow muffler. No other mods
Are these readings normal? Fuel pressure seems off?
Want to put on fass lift pump, s&b air intake , and edge comp. truck tows a lot and just looking for a little extra umps. Any ideas?
I believe that fuel pressure will damage injecter pump below 5 psi. That's why I think the gauge is off? The other ones I don't have a clue about. The EGT I drilled and taped manifold. Didn't know it was up and down so fast when on and off throttle. Boost seems to run and react normal.
