whats a good turbo?? help please.
Old Dec 14, 2013 | 08:37 PM
BranNinja's Avatar
Default whats a good turbo?? help please.
I have a 2006 Ford F250 XLT 4x4.
i have done some upgrades and was wondering whats a good turbo to go with. here a list of what ive done.
blue spring.
Fass System (non sure what one)
155cc injectors on stock nozzles
ARP Head Studs
Sinister Diesel EGR Delete
5 inch MBRP Turbo back exhaust.
and a SCT Livewire tuner.
Old Dec 18, 2013 | 07:16 PM
HeavyAssault's Avatar
Depends on your goals. A Pmax with a single bladed compressor wheels would be a GREAT add-on to the injectors. You could have the stocker modded to help. Depends on the money you want to spend as well.
Old Dec 19, 2013 | 11:44 AM
bustedknuckles's Avatar
What is the single bladed compressor wheel?
Old Dec 21, 2013 | 04:26 PM
jkidd's Avatar
powermax is a nice upgrade... you can sell your stock turbo too because there is no core.
Old Dec 21, 2013 | 06:49 PM
Pics to explain the different compressor wheels:
Stepped compressor wheel (Left) Single Plane compressor wheel (Right)
These are just an example. There are several variations out there for just about any turbo.
Last edited by HeavyAssault; Dec 21, 2013 at 06:49 PM. Reason: Automerged Doublepost
Old Dec 26, 2013 | 10:30 PM
6.0lover2's Avatar
I rebuilt an early 03 stock turbo. $100 for a kit and then threw on a wicked wheel2 $200. I went the extra mile and had it balanced. It was dead nuts so I only got charged $50. $350 turbo pushing 40psi
Old Dec 27, 2013 | 08:17 AM
Adrenaline junkie's Avatar
I was thinking about doing that 6.0 lover2! Thanks for feedback! Sounds like that would be a good step up over stock on a budget. I was wondering where you got rebuild kit? I hear there are different thrust washers available. 270 degree vs 360 degree washer?
Old Dec 27, 2013 | 09:57 AM
6.0lover2's Avatar
I got the 360 from pureturbo.com and I went straight to dieselsite.com for the wheel
I also got a thread that shows what the guts to the turbo looks like if you're nervous. Easy as heck though
Old Dec 28, 2013 | 05:31 PM
mach5customs's Avatar
I am in the market for a turbo as well, I have been looking at the MTW stage 1 turbo, it's perfect for stock to 155 sticks. It's also supposed to flow about the same as a pmax and spool faster than stock. Plus there only 850$ with a billet wheel.
Old Dec 29, 2013 | 05:07 AM
Since MTW is a rebuild you take your chances. A Pmax with a billet wheel will perform the same, since it's a new turbo it's does cost a little more.
The amount of PSI you read doesn't mean anything with regard to airflow which is more important.
