Oil pressure gauge
Old Dec 13, 2013 | 08:48 AM
Nathanpotts's Avatar
Default Oil pressure gauge
Where or how do I hook up an auto meter oil pressure guage on 96 powerstroke
Old Dec 13, 2013 | 10:40 AM
joebob3093's Avatar
Moderator
Think there is a port on the oil filter base
Are you wanting high or low pressure oil?
Last edited by joebob3093; Dec 13, 2013 at 10:40 AM. Reason: Automerged Doublepost
Old Dec 13, 2013 | 09:16 PM
I'm not sure I the difference but I just finished hooking up the boost gauge after having to go to oreilly's to get not compression fittings after loosing 3
Old Dec 14, 2013 | 01:27 AM
joebob3093's Avatar
Moderator
You will need to.know what you have to hook it up in the right spot
Old Dec 14, 2013 | 07:37 AM
There I a little port on the side of the book next to the oil filter housing that has an Allen wrench head on it and is about 3/8, I have the fitting and everything for this location
Block*
Last edited by Nathanpotts; Dec 14, 2013 at 07:37 AM. Reason: Automerged Doublepost
Old Dec 18, 2013 | 09:45 PM
Does anybody else ever hooked up an. Oil pressure guage?
Old Dec 18, 2013 | 11:07 PM
joebob3093's Avatar
Moderator
what oil pressure? at the filter base is low pressure, in the valley in high pressure
Old Dec 19, 2013 | 09:54 PM
Which do you recommend
Old Dec 19, 2013 | 10:30 PM
joebob3093's Avatar
Moderator
Neither are "needed". If it doesn't have low pressure oil it wont run, if it doesn't have enough high pressure it won't run as good as it could. You gain anything by having them other then maybe easier diagnosis someday and more gauges in the cab
Old Dec 21, 2013 | 10:12 PM
So is it the port with the maybe 3/8 bolt sticking out about 1/4 inch? My guage goes to 100
