Normal Cold Start??
Old Apr 15, 2008 | 10:10 PM
wildbill's Avatar
Default Normal Cold Start??
I got a video of starting my truck. This is the first time it started this quick (1 maybe 1 1/2 revs). Shakes like a trucker. Still trying to pinpoint why it starts right off the bat as shown here, and why it turns over 6-10 revs before fire. Dealer is going to charge to pinpoint and maybe one or more of ya can help. Oh yeah, it sat all night and half the next day, unplugged. TIA
http://s209.photobucket.com/albums/bb292/CTB06/?action=view&current=MOV00306.flv
Old Apr 16, 2008 | 08:11 AM
dalton06's Avatar
i cant figure it out either... Mine does the same dang thing. sometimes starts realy quick, and other times it turns over more that usual before it starts... I just cant figure it out
Old Apr 16, 2008 | 03:36 PM
06Dodge's Avatar
Sounds like my 06, it starts better cold then it does in the summer time when the engine is warm. But I have found out if I wait a bit longer when warm it will start almost as good as a cold engine. The only thing I can think of it some times it takes the ECU longer to get the timing set up for it to start.
Old Apr 16, 2008 | 06:11 PM
wildbill's Avatar
Was 56 all day when I fired it up. Why the grids heated I'll never know.
Old Apr 17, 2008 | 12:20 PM
06Dodge's Avatar
Your grid heater can come on any time the manifold temp is below 66 degrees.
Old Apr 17, 2008 | 06:35 PM
DieselfreakMI's Avatar
The varying in start time could be caused by location of top dead center of the number 1 cylinder when compared to the engine position sensors, such as the crankshaft position and camshaft position sensors. The computer must find the number 1 cylinder before it starts.
position may cause a the ECU to take longer to set timing
Last edited by DieselfreakMI; Apr 17, 2008 at 06:35 PM. Reason: Automerged Doublepost
Old Apr 17, 2008 | 07:10 PM
jfoose's Avatar
I don't know if it is correct or not, but the tech manual on the ISB through Cummins website says that the ECU won't let the engine start until it has reached at least 30 pounds of oil pressure. Don't quote me on it, I just happened to see it as I was skimming through an online manual. This might explain why it would start faster in cold weather, my 06 does the same thing. Last time it was below 15 degrees here it seemed to start before I could get the key all the way to the full starter engagement!
Old Apr 17, 2008 | 08:33 PM
It would have to crank alot to build that oil pressure before it started I would think.
I am pretty sure oil pressure is not the case
Last edited by DieselfreakMI; Apr 17, 2008 at 08:33 PM. Reason: Automerged Doublepost
Bigredpowerstroke
Aug 14, 2015 10:31 AM
Mike0885
May 27, 2015 12:07 PM
GHETTO_PIZZA
Mar 29, 2015 09:44 PM
ronstop
Feb 26, 2015 09:48 AM
custom7.3
Nov 23, 2014 10:44 PM
