Cold Start Idle Haze - Thoughts
Old Dec 11, 2013 | 12:56 AM
CrazyDog's Avatar
Default Cold Start Idle Haze - Thoughts
Hello Everyone,
Background:
For the past 6 months my truck is no longer a DD, and i mainly use it for the weekends or trips that require a truck. My truck can sit between 1-2 weeks before being driven, and I am now very good at giving it the once over before starting up (check all fluids and overall health). Upon startup, it always idles for 2-3 mins, followed by 1/4 throttle- about 5psi boast til first thermostat open.
Concern:
I have noticed as of late (maybe just paying close attention) that after starting, i am getting a slight haze for 3-15 secs after start up. I get the initial puff, followed by this light haze then clear. I tried to video the haze, but it wouldn't show up on video (have to view from an angle).
I use PS every fill up at the recommend amount, truck always fires right up on a half crank (even in 32* temps), idle/revs smooth, no knock and never smokes/hazes besides this first time start up after siting.
I am thinking its either a sign that injectors may need to be addressed in the near future or my grid heater is on its way out.
Thoughts?
Old Dec 11, 2013 | 02:24 PM
tbirdz24v's Avatar
What color is the haze? I drive mine every day 90 miles round trip to work. Its been at 10 degrees when I leave work and it stays plugged in the whole. It also is idling at about 1400 RPM. I also have a haze at initial start up. Clears up in a minute though. Its common for cold weather. I'd only really worry bout it if it would continue while driving after warm up.
Old Dec 12, 2013 | 11:55 AM
jigabop's Avatar
haze is nothing to worry about.
at least you don't have constant haze like mine . but mine is caused by very large injectors. it hazes warm or cold 80% of the time..
Old Dec 13, 2013 | 01:08 PM
AMS247's Avatar
I would say but what you stated it sounds like you are perfectly fine. I wouldn't worry about it.
Diesel doesn't like cold weather as much and because of the cold all the fuel doesn't burn as well as it would if the engine were warm. 15 seconds is completly normal.
Old Dec 14, 2013 | 01:36 AM
CrazyDog's Avatar
Its odd, I could not describe the color because its more of a clear haze if that makes any sense. If you stand right next to the exhaust you can't really see it, but the further you walk back (say 10ft). That is when you notice that there is a "haze" coming out of the tail pipe because there is visible, yet colorless cloud.
It just seemed odd, since its not even that "cold".
When I use to DD it, I never noticed it but now I am starting too. It has only hazed 2 out of the last 5 starts, which lead me to think it was starting to show signs of a part being worn. Something to do with the extended time it sits.
Average temp for the last 5 starts (roughly 2 weeks in-between drives)
- Night = 30's
- Day = 40-50
Old Dec 16, 2013 | 04:29 PM
jigabop's Avatar
30s-50s is cold for a diesel...
diesels love summer weather and they love running on a warm/hot engine. cold engine they don't perform as well, they are louder, and they don't start as easily.
combustable fuels burn better when they are warm.
Old Dec 19, 2013 | 07:32 PM
AMS247's Avatar
x2
The grid heaters on our trucks will engage below 69*. So if you think about it, they're designed to activate at that temp range because even that is just not what a diesel engines likes. 30*-50* is right in that relm for the grid heaters to turn on for 10 seconds.
It could be the more you're looking the more you're noticing. It could have always been hazing in that temp range. Sort of like when you work on your truck and then during the first test drives you might worry yourself because you may hear a bunch of "unusual" sounds, when the main reason you've never noticed those sounds was because you never payed that much attention before.
Colorless haze is completly normal
Bigredpowerstroke
Aug 14, 2015 10:31 AM
Mike0885
May 27, 2015 12:07 PM
ronstop
Feb 26, 2015 09:48 AM
robbyS
13
Dec 20, 2014 04:25 PM
custom7.3
Nov 23, 2014 10:44 PM
