6.7 dead.. NEED HELP NOW please..6
Old Dec 10, 2013 | 01:47 PM
1st_gen_puller's Avatar
Default 6.7 dead.. NEED HELP NOW please..6
Ok.. 2007.5 6.7 cummins 6 speed manual.. deletes smarty sr. straight pipe.. fass fuel.. while trying to drive down the road it willjust intermentinly defuel.. for ladck of a better definition... its like you floor it then completely let off gas pedal and it does that like every 4 seconds... fuels for say 7 seconds then falls on its face for like 4 seconds... all my guages stay the same so i don't think its electrical... put new fuel filters fuse and relay on fass so i dont think thats it..i really need help... if ya'll have to have codes i will get them but if you have any ideas please help me.. it has 300,000 miles...
Old Dec 10, 2013 | 10:59 PM
lukesdiesel's Avatar
Could be CP3 or Injectors
Luke
Old Dec 16, 2013 | 12:28 PM
EEWWWW.. don't say that... what would be the reason for popping fass relays???
Old Dec 16, 2013 | 02:41 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
sounds like something wrong with your fass pump. you might call fass and tell them about relay problems
Old Dec 30, 2013 | 07:19 PM
pulled a low rail pressure code and an intermittent pcm/ecm supply voltage low code.. any more ideas?? could the fass have a hole between tank and pump causing it to suck air and overwork itself?? or should i be looking towards my charging and electrical system?? acts like fuel problem to me but what do i know
Old Jan 2, 2014 | 01:08 PM
TTT
Old Jan 4, 2014 | 06:25 PM
tiremann9669's Avatar
The supply volts low would have me lookin at the electrical, if the volts to the pump are low the electrical issue could be causing a fuel issue.
Old Jan 8, 2014 | 12:24 PM
Well i have fixed the problem and i don't think ya'll will ever guess the cause of this!!! tire man your are right but WHICH electrical part..
Old Jan 11, 2014 | 11:42 AM
Ok guys this actually did not fix this problem... i've traced this problem back to my fass.. i think.. it will hold 18 pounds until you rev it then it will drop to 0 and not rebuild but will still run..
burndiesel
10
Feb 7, 2023 01:15 AM
CCC1971
6.7L Performance
Nov 20, 2017 04:49 PM
brand97
Jul 21, 2015 09:16 AM
Adam65
Jan 9, 2015 11:50 PM
