2001 cummins boost promblem
Old Dec 7, 2013 | 12:08 AM
ramrunner01's Avatar
Default 2001 cummins boost promblem
hey guys new to the forum seen but anyways i have a 2001 cummins automatic with the edge juice with attitude and 4 inch exhaust new lift pump everything else is stock and i was driving the other day and noticed that with my chip turned all the way to 5 i dont get the power or the boost i used to the truck still smokes like she always has and i can hear the turbo spool i just dont get the throttle response i used to get i have no idea what could cause this according to my edge chip i have plenty of fuel pressure does anyone have any thought on what could be causing this? the most boost i have seen sense this problem on setting 5 is about 17psi and just cruising im getting about 4-6 HELP!!!!
Old Dec 7, 2013 | 12:17 AM
BarryB's Avatar
sounds like you and I are in the same boat.Your set up sounds pretty close to mine, 17PSI is all I can get out mine as well. I believe my problem is a boost leak or the wastegate actuator is stuck partially open. I haven't had a chance to really check into it to find out what is going on.
Old Dec 7, 2013 | 12:22 AM
how would i check if my wastegate is stuck open? did yours randomly do this or has it always been like this? my used to boost more now its like it just does not want to boost anymore still drives fine just does not wanna go as fast anymore i guess is the best way to explain it
Old Dec 7, 2013 | 02:14 AM
tbirdz24v's Avatar
First thing I would do is turn down your programmer until you find the boost issue. I'm guessing you have an egt gauge. Watch it closely. Keep from any harmful damage happening. You should have a hy35 turbo on your truck if its stock. I'm not sure the best way to check the wastegate. I make about 19 psi with my programmer off. Other thing is a leak. Could be anywhere from where air enters the turbo to where it comes back out. ( charge air cooler, tubes, intake manifold, or exhaust manifold. ) all those are where it will drop boost. Hope some of this helps.
Old Dec 7, 2013 | 11:27 AM
thanks for the replies i took your advice and backed my programmer down to stock and noticed i will make about 15 pounds of boost even on stock but when i turn it up to 5 i get basically the same out of it could it be the wastegate freezing because the temperature is 3 degrees here the past 3 days thanks for your help guys
Old Dec 7, 2013 | 10:23 PM
BarryB's Avatar
Mine has been this way. I was wondering why my truck is slower compared to the last cummins truck I had. My truck now isn't a daily driver so I work on it when I get a chance to. edge comp on 5x5 17 psi max. I am pretty sure my intercooler boots are cracked and leaking air. Factory boots and my truck has 238k on the clock. make your self a boost leak checker. https://www.dieselbombers.com/dodge-...tructions.html
Old Dec 8, 2013 | 02:24 AM
H.R.D's Avatar
Sounds like a boost leak, like BarryB said, build the tester. I know I found a major leak in my positive pressure side using the BP tester, the tester is cheap and effective at testing for boost leaks.
Do you have the J-hook for that hy35?
Old Dec 8, 2013 | 04:22 PM
Where do I buy the tester or how do I build one
I will have to check tmw if it has a j hook
Last edited by ramrunner01; Dec 8, 2013 at 04:22 PM. Reason: Automerged Doublepost
Old Dec 8, 2013 | 04:38 PM
BarryB's Avatar
I posted the link to it in my last reply . here it is again in case you missed it. https://www.dieselbombers.com/dodge-...tructions.html
Old Dec 8, 2013 | 04:48 PM
thanks Barry B i did miss that link, it doesent sound to bad i think its a leak, hopefully i can get one of these built this week its driving me nuts or i may just buy a new boot and clamp kit if anyone has any good places to buy a nice set
