Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
New to Duramax Need Trans Help?????
Old Dec 6, 2013 | 04:55 PM
bigphil23's Avatar
Sad New to Duramax Need Trans Help?????
Ok so I just bought a real clean 2005 Duramax. It has 194xxx. Lifted 6inches with 35's. No chip or programmer, although the guy I bought it from had a PPE on in before I bought it. Had it now for a few weeks, and has ran like a champ. No problems to speak of. Just this morning I drove it to work and it ran fine. Parked it on a level service. Came out at lunch, fired right up and I put it in drive. It slams in to drive pretty hard, almost like it was parked on an incline or something. Sounded like a U joint. Then it throws a code. Drive it around a little bit, goes in to reverse but every time I put it in drive, it goes in real hard, although it shifts normal when in gear. Checked the U joints and underneath around the transmission and looks just fine. I checked the codes this evening and I get...
P0700 and P0872.
Its not acting like its in this "limp" mode I have heard so much about. But is it limp mode? Just curious as to what might be causing this and how to fix it. I don't drive it hard at all and like I said, its has nothing on it right now, and hasn't for the last 6 weeks at least. Any help would be appreciated.
BTW I am new to the Duramax. I have ran only Cummins until now. This is going to be a learning experience for me. I'll take all the information I can get.
Old Dec 7, 2013 | 09:11 PM
NSJimmyStarr's Avatar
Good luck getting a reply. Seems like people here either don't know anything or are biased to newbies. Best of luck with your issue.
Old Dec 21, 2013 | 04:52 PM
crazycooter's Avatar
p0700 is a circuit fault set by your tcm, or trans control module
p0872 is set by your pressure switch manifold, made up of 4 pressure switches, 3 normally open, 1 normally closed. this would be your malfunction.
trans will fail to hydraulic default,
TCM freezes shift adapts
tcm inhibits tcc lockup
This comes from page 7-901 in Volume 4 of the silverado / gmc / denalli service manual set
Jake9473
Jul 22, 2018 08:19 AM
dc2188
Sep 5, 2015 10:41 AM
Rabbitjbu
Jul 28, 2015 06:03 PM
jt19
Jul 13, 2015 03:06 PM
duramaxtuner
Dec 10, 2014 01:24 PM
