horrible fuel leak
Old Dec 6, 2013 | 02:58 AM
redbeard007's Avatar
Default horrible fuel leak
Ok guys i have an old 6.2 out of an 82 van. I drove to work today everything was fine til i put it in park and sat at an idle. It started idling pretty rough. On my way in i noticed i had a puddle under my truck so i opened the hood to find out it is leaking from the metal fuel line in between the line and nut it was not a slight leak it was squirting out fuel all over everything and was running horribly. Could my injector be bad? I havent had any time to work on it. Any ideas would help. It wasnt leaking before this thats why im wondering if my injector has failed. Please help. Thanks
Old Dec 6, 2013 | 07:33 AM
racer55's Avatar
Need a picture to decipher what line you are talking about?
Injector line?
injector return line?
IP feed line?
Old Dec 6, 2013 | 11:45 AM
It is the metal line that runs from injection pump to the injector. Im guessing injector line. Its not a return line and it comes from the injection pump not feeds to it. But like i said its spraying out like a geyser in between the line and the fitting. Almost as if i forgot to tighten it but again it wasnt leakin before
Old Dec 6, 2013 | 11:55 AM
racer55's Avatar
Better loosen it off and tighten it again-otherwise you might need a new line and/or injector?
Could be that you damaged it or it has debris in the sealing area?
Or it just isn't tight yet?
Old Dec 6, 2013 | 12:04 PM
The thing is i didnt loosen it i havnt messed with them cuz everything was running great. Idk maybe it worked itself loose im just a bit confused an it dont help that i havnt yet had time to tinker with it
Old Dec 6, 2013 | 12:07 PM
racer55's Avatar
Could just be a fatigue in the metal line?
Or it wasn't tight enough to start with?
Old Dec 7, 2013 | 12:57 PM
K ill go tinker a bit
Well i took the line off it broke free easy but didnt seem that loose so i looked at it looked fine put her back on tightened it goodntight then i killd my batteries startn it fml chargin it up and hopefully the leak is gone if not i hav no idea
Well its still leakin.....im confused
Last edited by redbeard007; Dec 7, 2013 at 12:57 PM. Reason: Automerged Doublepost
Old Dec 7, 2013 | 03:54 PM
racer55's Avatar
You sure it's the high pressure line leaking and not a rubber return line?
Old Dec 7, 2013 | 04:19 PM
Im sure...the high pressure line goes thru the fitting that fastens to the injector...its dumpin out in between the line and the fitting....its not the return lines
I hav fuel all over my pass side of the engine bay...id say there is sum pressure behind it
Last edited by redbeard007; Dec 7, 2013 at 04:19 PM. Reason: Automerged Doublepost
Old Dec 8, 2013 | 10:31 AM
racer55's Avatar
Ok then the injector and/or the line are damaged and need replaced.
Injectors should be replaced as a set.
