W250 spd 4" exhaust
Old Dec 3, 2013 | 11:29 PM
jbeartahoe54's Avatar
Default W250 spd 4" exhaust
Ok here the spill. Time for my old truck to get better mileage, and up the power. I purchase ever thing to run an inter cooler. This includes both inter cooler hoses. 1993 inter cooler. Denny T Fuel Pin stage 2. Gauges, Boost Pyrometer, RPM. I have an HX35 turbo. What will it take to adapt it in? what intake Elbow can I install to make air flow nice and smooth? Now what injectors do I need? I am looking at the DDP .50LPM. I run 40% WVO. I plan on having the pump tuned and add a Lift pump. I looking to either purchase a Airdog II 100 Or 165, but am having trouble deciding on which one. Or should I just run a Modified H40?
Oh an I have a 3200 rpm gov spring for it
Last edited by jbeartahoe54; Dec 3, 2013 at 11:29 PM. Reason: Automerged Doublepost
Old Dec 4, 2013 | 08:03 AM
NadirPoint's Avatar
You have alot of work to do. The i/c won't bolt up to the core support. You are going to either need a 91.5-93 core support or some fab work to get it in there.
Old Dec 4, 2013 | 11:11 AM
ok thank for that info. So it looks like a H1C that been work over might help me out then.
Old Dec 4, 2013 | 12:31 PM
novapat's Avatar
Theres venders on this site that can help you with injectors. ddps in my opinion are junk.. I had a injector stick and burnt a piston.. had to argue with larry at ddp and threaten to take him to court to get my money back!!! Very bad exper!!!!
Old Dec 4, 2013 | 02:24 PM
lukesdiesel's Avatar
DFI injectors
Luke
Old Dec 4, 2013 | 07:25 PM
Thanks. I am Learning on this and your help is much apperated. My goal is to have bwhp to be around 225 to 300. and to still get the mileage or better. So What sticks would help and what turbo can I install to make this happen with the Denny T stage 2 the Airdog II 100 3200 spring.
Luke which injector to run?
Last edited by jbeartahoe54; Dec 4, 2013 at 07:25 PM. Reason: Automerged Doublepost
Old Dec 9, 2013 | 12:04 PM
Ok Found out I need to run 5x012 155 degree injectors. now going to order them. now need to find a good cross over intake pipe. any idea where I could get one?
Old Dec 9, 2013 | 07:54 PM
SMOKE TRAIL's Avatar
if you're planning on running the stock h1c(assuming its one off a non-ic'd truck) this guy makes them to bolt right on. 1989 -1991 CoolerTubz
but if you want to run a later model h1c(1991.5-93) or an hx35, they have a v-band flange on them.
Old Dec 10, 2013 | 07:45 AM
Smoke Trail, Awesome Link. And yes I am going to run an HX35. so I will need the V-band. What size, and will I have to adapt of fabricate a tube up?
MY Bad 5x.013 155* degree they will be a new batch in about 2 to three months is what I am told. Good deal Now I know
Last edited by jbeartahoe54; Dec 10, 2013 at 07:45 AM. Reason: Automerged Doublepost
Old Dec 15, 2013 | 02:36 AM
Any idea which Airdog II I should run 100 or 165?
