Should I change my head studs or head gasket now?
Old Dec 1, 2013 | 09:06 PM
Dunright mobile's Avatar
Default Should I change my head studs or head gasket now?
So I've got a edge juice/w attiude afe air cleaner wide open exhaust fass150 pump and 60 hp injectors on the way. I've gotten my boost up to 37 psi before. Should I be doing some head studs or a gasket now ? I should mention I have the HO motore (245 hp)
Old Dec 2, 2013 | 01:11 AM
97cummins's Avatar
I would say go head studs, but if your going to be increasing the pressures, I would upgrade the head gasket and do both at the same time.
Old Dec 2, 2013 | 11:27 AM
lauber_03's Avatar
x2 for head studs if you do plan to go bigger later on. i wouldn't change the head gasket unless there is something wrong with it.
Old Dec 2, 2013 | 11:28 PM
jkidd's Avatar
I would turn your boost down to 32psi and save your money for things that will make a better difference like better head lights. or a high idle switch.
Old Dec 6, 2013 | 11:30 PM
24isjustright's Avatar
Head studs is another way for someone to make money run it tell there's a problem
Old Dec 7, 2013 | 12:42 AM
I set my boost down to 35
Old Dec 7, 2013 | 10:35 AM
megacab350001's Avatar
I agree turn boost to 32 save$$
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
turbodiesel123
Nov 28, 2014 08:36 PM
HE22871
Nov 26, 2014 03:15 PM
1994cummims
9
Oct 15, 2014 11:37 AM
