Blew turbo hose, now won't start
Old Dec 1, 2013 | 11:04 AM
04-6.0hshouldagota7.3's Avatar
Default Blew turbo hose, now won't start
I was going down the road at 70 two hours into a three hour trip when I heard a loud pop, immediately I pulled over and inspected. I didn't see anything and the truck was idling fine so I started driving again. I realized I had no powere and I didn't have boost so limped it to the next exit. I shut the truck off put the pipe on and started truck, revved once to listen to turbo and truck stalled. Tried to start again but truck gave some sort of code through the chime. I cycled the key eight or so times and code went away and I started truck. No cel at any point. Went to get back on freeway and drove great for 1-2 miles and died. Now won't start. 1200 miles since new ipr, icp, hpop, crank position sensor, and egr cooler/egr delete. Question is are the two issues connected or are they separate. I have seen stuff on each one separately but nothing showing them together. 103,000 miles f250 2004. Scangauge2 shows icp at 23 ipr at 84% when cranking ficm is 48 volts and I get sync. I know the icp is low but any other info is appreciated. Thanks
So I have done a little more digging. I haven't found any correlation between the turbo hose and the no start however it seems my icp reading might be in default. It reads 23 before cranking with key on and during crank. Also there is no movement on the dash oil pressure gauge. I am leaning towards an oil pump but don't want to throw parts at it. Anyone with suggestions or experience please feel free to chime in. Thanks!
Last edited by 04-6.0hshouldagota7.3; Dec 1, 2013 at 11:04 AM. Reason: Automerged Doublepost
Old Dec 1, 2013 | 11:15 AM
mysterync's Avatar
Wow. That alot of replacement parts above. Why was everything replaced? Witg the oil filter removed does the oil filter housing fill up with oil when cranking?
Sent from my SCH-I605 using Tapatalk 2
Old Dec 1, 2013 | 11:25 AM
I had the crank sensor go out as well as my hpop. I replaced the ipr/icp At The Same time. I did the egr immediately after. So yeah a lot of parts and work 200 miles after buying the truck. I will check that when a buddy comes over and post my findings. Thanks for the response.
Old Dec 1, 2013 | 11:45 AM
bkmac's Avatar
This is a long shot but check your turbo for being stuck.
Read this post it may help - Mike's turbo was hung up and the truck would not start. Where your inter cooler hose was off maybe you sucked something into the turbo - again its a long shot.
https://www.dieselbombers.com/ford-p...-no-start.html
Old Dec 1, 2013 | 05:47 PM
Mysterync- I checked and I am getting oil while cranking. While there I checked filter and no metal shavings or debris.
Bkmac- I read the article and I checked the turbo and it is free. I don't believe I have any issues with that. Thanks for the shot in the dark though, that's free and one more thing to cross off.
Old Dec 3, 2013 | 10:58 PM
If anybody is still interested or reading this thread with experience/information, my truck seems to have a clunk-thud every one one-thousand count while cranking. It's not real loud but it's there. Please, somebody somewhere has to have had this issue or one like it before. Thanks.
Old Dec 4, 2013 | 07:09 AM
mysterync's Avatar
Sorry I've not replied. Been busy in the shop.
I could throw guesses your way all day and might get lucky, might not. You'll need to find a decent shop to get some data from the truck. Once thats done we can help you a bit more.
Old Dec 4, 2013 | 07:39 AM
Adrenaline junkie's Avatar
Wondering why hose popped after two hours? Is there a lot of oil in your cac tubes? Start with basics, clean air, fuel and oil. Make sure ficm volts good and is syncing. Make sure you have clean fuel getting to the injectors, there is test port on fuel bowl for pressure check. Make sure you have high pressure oil for injectors to fire. Most scan tools will give you enough info to help with diagnosis. It's confusing at first but not too difficult if you want to learn.
Old Dec 5, 2013 | 10:18 PM
Ok low oil pump checks out, high pressure checks out, ipr checks out, icp never moves off 23 on the scan gauge. Unplugged icp reads 1776 and ipr reads 54%. Still no start. Checked wire looms and they are good. Anything I am missing? If I was in a position to pay for a shop I wouldn't be asking you guys. Not trying to be a b-hole but I am stumped. Watched the diesel Ron vids on you tube and still stumped. I no longer care about the turbo and the cold side of the road it left me on. I am concerned getting it fixed and pronto! Thanks guys.
Old Dec 6, 2013 | 07:11 AM
Did u check ficm volts again? It's possible you may have defective ICP sending unit. You need the oil pressure and electronics working together to get your injectors to fire. Also do u have fuel pressure at filter? Lotta things come together like orchestra on modern diesels. . U can do it!!
