2003 6.0 Fuel in Oil
Old Nov 28, 2013 | 10:52 PM
The Bacon's Avatar
Question 2003 6.0 Fuel in Oil
Here I am again with another problem with my 6.0 Powerstroke.
I have driven around 3500 miles since doing a new HPOP and the ball bearing came out of the side, well the pump is out of the 90 day reman warranty I got with it so I tapped/plugged the ball bearing hole. Everything was functioning normal for about another 500miles. I checked my oil and it was way beyond full so I drained it and determined that there was fuel in the oil. After reading through several forums I have decided to do new Injector o-rings and hopefully that will fix it, I figure the $90 for new O-rings is a worthwhile investment.
My question is, Will my ICP reading be low if the oil is diluted enough?
ICP Desired at WOT is reading 3200-3400, Actual is topping out around 1500. I am just trying to determine if I need a new pump while I am back in the engine or will fixing the fuel leaking into the oil resolve the problem.
Thanks for any help in advance.
Dbleo351
Nov 20, 2016 09:34 AM
Cavnar
Sep 9, 2015 07:18 PM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
emilio2496
8
Jan 13, 2015 05:03 PM
