Transmission fluid change 47re METAL PIECES FOUND
Old Nov 27, 2013 | 01:10 PM
smokybob's Avatar
Default Transmission fluid change 47re METAL PIECES FOUND
Hey all
First transmission fluid change since purchasing of my 2001 24 valve cummins. I found these two larger metal pieces.
Has anyone else found these?
Is this a big problem?
Does anyone know exactly what they belong to?
The pieces together appear that they would form a ring shape.
Transmission status: 196K miles believed to be stock tranny. When fluid just dropped it appears to be very used.
Shifting:
1) jumps 300rmps up/down when cruising at approx 35mph. (1200-1500 rpm back and forth)
2) hard shift and slight shudder when shifting into overdrive.
I purchased new fluid, filter/gasket, pressure sensor transducer, and solenoid to fix the problem. . . but then found these pieces.
Thanks bob
Attached Thumbnails Transmission fluid change 47re METAL PIECES FOUND-photo-45.jpg
Old Nov 27, 2013 | 01:24 PM
mysterync's Avatar
Hard to tell but looks like one of the snap rings. Looks like its time for a build.
Sent from my SCH-I605 using Tapatalk 2
Old Nov 27, 2013 | 02:07 PM
smokybob's Avatar
well, seeing that its winter here and only 30 degrees, and that I am a bartender not a mechanic, anyone have a good shop in Colorado or the four corners region?
Old Nov 27, 2013 | 05:19 PM
clementsdiesel's Avatar
who knows how long those have been in there I would think if it was going to break it would of already I know its not the best thing to do but if it was me I would drive it till you notice things getting worse
Old Nov 27, 2013 | 07:04 PM
mysterync's Avatar
The concern would then be additional damage to internals. You may go from a $3500 to 4500 or more if you had to have hard parts.
Old Nov 27, 2013 | 11:06 PM
Im not going to say its cheap but from my experience complete stock 47re transmission rebuilds don't cost that much were talking 2100-2500 bucks that's labor fluid and taxes you get into the 3500 4500 range when you start beefing stuff up and that's a lot of stuff beefed up
mysterync im not saying your wrong things may be higher were your at
Old Nov 28, 2013 | 08:52 AM
mysterync's Avatar
Why would you put a stock rebuild under anything? These transmissions had problems which caused alot of headache for their owners. If your going to drop 2k in something why not go ahead and go with a 3d converter, extra clutches, upgraded band apply and a vb?
Old Nov 28, 2013 | 09:03 AM
im not going to argue im just saying my two cents everyone has different opinions
I couldn't afford a 3500 transmission rebuild I could afford a 2500 rebuild not everyone has money for that extra 1000 just an option
Old Nov 29, 2013 | 11:56 AM
smokybob's Avatar
Right. That is where I am at. The modifications on this truck are unknown to me besides the obvious. chip, exhaust, intake, intake elbow etc... A stock tranny might not hold up well, and the forest road I pull horses and hunting gear up will eat a 47re even in a completely unmodified cummins so a beefed up tranny is my best option. One big problem is right now I can't even afford a simple rebuild. I may have to drive it the way it is for awhile.....thanks for the help guys. Im sure Ill have more questions on this in the future
Old Dec 1, 2013 | 08:54 PM
Dynamic's Avatar
Those are pieces of your overdrive direct clutch snap ring. It's very common to find those broken upon teardown. It should always be replaced at overhaul.
You should be able to have a very good build done for around $2500-3000, including converter...
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
PD4Life
Aug 24, 2015 08:11 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
nomoney
Jun 16, 2015 08:16 AM
Bigredpowerstroke
Dec 19, 2014 05:18 PM
