Factory lift pump wiring harness missing ???
Old Nov 25, 2013 | 11:12 PM
Dunright mobile's Avatar
Default Factory lift pump wiring harness missing ???
I put my fass 150 in tonight. It was tough but every thing worked out. My problem is that I can not find my factory lift pump connection. my lift pump went last yr and my mechanic put a new lift pump in my tank (took out factory pump) Now I can't figure out where to hook up my fass wiring harness ??? Any ideas. ?
Old Nov 25, 2013 | 11:17 PM
lauber_03's Avatar
there should be a two plug connection coming off of your ecm. If your mechanic removed it for whatever reason your gonna have to do some new wiring
Old Nov 25, 2013 | 11:51 PM
Ya I hope he didn't do some thing stupid like cut it
Old Nov 26, 2013 | 12:12 AM
lauber_03's Avatar
Mine is cut, the wiring coming out of my ecm for the lp was burnt up so i just grounded my airdog harness to the block and ran a better hot wire from the ecm that goes to my relay(harness that came with airdog). not stock or easy with the connections if i have to remove it but it works and i don't plan on selling my truck.
Old Nov 26, 2013 | 12:14 AM
If I can't find mine I'll be doing that
landon025
Sep 8, 2015 09:21 PM
ctjkelley
Jun 3, 2015 06:01 AM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
