125hp Edge Injectors??
Old Nov 25, 2013 | 08:47 PM
OlRed2ndGen's Avatar
Default 125hp Edge Injectors??
Would it be a bad idea to put 125hp Edge Injectors on 01 24v Cummins.. has Fass Dodge Replacement Pump with bigger fuel line then stock. Mild built trans has billet input shaft and hub, TCS Triple lock super duty converter, and a shift kit. Already have pillar gauges. Or do I just need to put a bigger lift pump on like a Fass 150 before anything? Just curious if its safe to do 125hp Edge injectors with the few aftermarkets on my truck?
Old Nov 25, 2013 | 11:53 PM
lukesdiesel's Avatar
I would skip the Jammers... They are dirty injectors. I would recommend some Big Dawgs or DFI Injectors.
Luke
Old Nov 26, 2013 | 10:53 PM
And I'll be fine with my Fass DRP Lift pump? I have 3/4 inch fuel lines.
Old Nov 27, 2013 | 12:44 AM
Pokechop's Avatar
I imagine you'd be fine as long as you keep your fuel pressure above 15psi at all times. I'm running DAP 125hp 7x.0095 injectors on two Carter P4601HP pumps and making 18psi.
Renteria1217
19
Oct 13, 2015 01:36 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
