Fass install
Old Nov 25, 2013 | 03:23 PM
Dunright mobile's Avatar
Default Fass install
Hey guys I got my fass 150 today. I plan on installing it tonight. Any pointers? I'd like to run it to my stock fuel canister if I can, for the fuel heater, I got the suction tube with it as well
Old Nov 26, 2013 | 11:26 AM
jigabop's Avatar
you mean run it to your stock fuel filter housing?
the fuel heater is in the fuel filter housing, not in the tank...
Old Nov 27, 2013 | 09:28 PM
Yes thats what i ment. I allready installed it. I ran it to the stock fuel filter. Works great. 15-16 psi idle 13 psi WFO!
Old Nov 29, 2013 | 11:08 AM
jigabop's Avatar
13psi is a little low for WOT... might wanna bump up the pressure a wee bit...
I run my airdog150 at 20psi idle and hit 16psi WOT
Old Nov 30, 2013 | 08:53 AM
How do I up the psi?
Old Dec 2, 2013 | 11:50 AM
jigabop's Avatar
gently stretch the spring a little.
should be a spring and ball behind the return fitting. the spring pushes the ball against the hole blocking fuel from returning till fuel pressure rises enough to overpower the spring and push the ball back allowing fuel to return to the tank. stretching the spring slightly will increase spring pressure against the ball thus raising fuel pressure.
JoeyMiR
9
Feb 3, 2018 10:05 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Jet A Fuel
Jun 5, 2015 03:28 PM
gumborancher
Apr 24, 2015 01:25 PM
jdepuy618
For Sale
Dec 21, 2014 05:28 PM
