4 codes
Old Nov 24, 2013 | 10:48 AM
husky1's Avatar
Default 4 codes
p2037 p2036 p0237 p0236 pressure sensor for turbo on manifold?
Old Nov 24, 2013 | 04:14 PM
jigabop's Avatar
sounds like your MAP sensor is shot
voltage too low, voltage too high too long, overboost, etc...
sensor is throwing too low and too high of voltage readings that are out of spec which usually means either a rodent chewed through the map wires, or the map sensor itself is dirty/shot and needs replaced...
the sensor is located on the drivers side of the head in about the middle of the head around the fuel filter area.
Old Nov 26, 2013 | 10:01 PM
husky1's Avatar
Default engine miss
fixed map sensor no codes but she misses now..injector would throw code?
Old Nov 27, 2013 | 11:41 AM
jigabop's Avatar
probably not..
you can take it to a dealer and have them do an injector kill test to see which injector is bad...
if it really is an injector bad then replace the whole set...they are cheap enough to do all of them on a 24v.
common rail would be a different story since their injectors are ridiculously expensive, but lucky for us, we don't have common rails
Old Nov 28, 2013 | 11:38 AM
husky1's Avatar
Default 2 gen
fixed code now sputter blue smoke when warm ..no codes .??????????new fuel filter in min
longhorn12
6.7L Performance
Aug 29, 2015 01:28 PM
schwier94
Mar 8, 2015 06:09 PM
KimberlysTruck
Mar 5, 2015 06:28 PM
Renowest48
Dec 14, 2014 08:36 PM
Altonlee
9
Oct 8, 2014 02:31 PM
