Grid heater issue.. Help confirm my thought
Old Nov 24, 2013 | 08:31 AM
outlaw1_gt's Avatar
Default Grid heater issue.. Help confirm my thought
I replaced my grid heater realays the other day i have had a battery drain issue.. When i went to hook the fusible link from the relays to the battery the wire would spark off the battery.. Next guess is to replace grid heater.. Or is there another problem????
Old Nov 24, 2013 | 09:16 AM
mysterync's Avatar
Relays control the power supply. The grid heaters just use the power. I would recheck wiring. Check for continuity accros the supply and feed of the relay with it off. If theres continuity you know its a faulty relay.
Sent from my SCH-I605 using Tapatalk 2
Old Nov 24, 2013 | 05:16 PM
tiremann9669's Avatar
I'm betting on the relay, I had a battery drain issue and when my shutoff selonoid relay burned out my battery drain issue was cured.
Old Nov 24, 2013 | 06:50 PM
outlaw1_gt's Avatar
Guess i got some bad ones straight out of the box
Old Nov 24, 2013 | 07:17 PM
mysterync's Avatar
Very common these days.
dodge2014
Apr 16, 2015 08:54 PM
95 cummin
Jan 21, 2015 11:54 AM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
justinsbeck
Nov 22, 2014 03:03 AM
