odd smell
Old Nov 23, 2013 | 12:26 PM
roadchaser's Avatar
Default odd smell
I have been smelling something that smells like hydraulic fluid.I looked under the truck this morning and there was a grayish looking fluid on the cement floor, not much.It smells like hydraulic fluid..I can also smell it when the truck is running if i am standing by the motor.
I lifted the hood and so no leaks.It leaked under the truck about where the transmission and transfer case are located.Could it be an oil leak?I am not a mechanic at all.Any help would be appreciated. Thanks in advance.. Peace and Prayers
Old Nov 23, 2013 | 07:35 PM
Pokechop's Avatar
The Haynes manual for our trucks recommends running the same gear oil from the differential in the transfer case, so that's where I would start checking for leaks. I don't know the smell of hydraulic fluid, but I know gear oil has a really strong odor. You don't have a signature yet, so I don't know if you're running an auto or manual transmission. If you have a manual transmission, I'd check PTO cover bolts and the drain plug. If you have an auto, the fluid would be red/brown... and you mentioned the fluid is grayish, so I wouldn't suspect transmission. Hope this helps pinpoint the problem!
Old Nov 24, 2013 | 06:28 AM
roadchaser's Avatar
I have a 5 speed transmission.Where is the pto cover bolts and drain plug located?
All the best..
I think you are right on the smell of gear oil. I had a mechanic just 10 days ago check all fluids.Front and rear housings along with the trans&transfer.He said he added some to the tranny and transfer but the front and rear housings were full. Thanks
Last edited by roadchaser; Nov 24, 2013 at 06:28 AM. Reason: Automerged Doublepost
Old Nov 24, 2013 | 08:08 AM
Pokechop's Avatar
There are two PTO covers, one on each side of the transmission. They are located near the front of the transmission and have 6 bolts holding them on. Check the bottom-most bolts for leaking. (I don't have the proper hex for removing the drain plug on mine, so I drain it by removing the driver's side cover... I don't know if there are gaskets for the cover, but I use gasket-maker to seal!) If not the PTO cover, I would tend to suspect that transfer case. If you see no leaks at the drain lug, maybe there's a seal that's leaking? If nothing else: crank it up, drive it around, pull it back into the garage and watch for leaks.
rocanater
Ford Powerstroke 08-10 6.4L
Sep 29, 2015 04:38 PM
51Hudson
10
Aug 5, 2015 12:32 AM
moparman70
Jul 30, 2015 12:38 AM
Cutlass26
Mar 22, 2015 05:46 PM
6btf350cummins
Dec 16, 2014 07:23 AM
