New to powerstrokes
Old Nov 21, 2013 | 03:11 PM
That1Guy's Avatar
Default New to powerstrokes
Im a Cummins Light Duty technician, but have not owned my own diesel yet. I found a good deal on a stock 97 f250 7.3 2wd with a 5speed (ext cab long bed) im going to be using the truck for daily driving and pulling the racecar trailer/ boat on the weekends. no more then 8k lbs. what do i need to do to this all stuck truck for best economy and ease of towing?
Figured dp, exhaust, intake.. at this time not wanting to do injectors yet.
Old Nov 21, 2013 | 03:26 PM
autostroker's Avatar
For what you are going to do...that will be plenty. Dont worry about injectors unless you are going high hp and boost. Then change head studs and gaskets first. 7.3 is good engine and should run a long time.....i have 363000 on mine and all ive done to it is hpop intake and exhaust.
Sent from my SCH-R970 using Tapatalk
Old Nov 21, 2013 | 03:34 PM
That1Guy's Avatar
What about a chip? Whos good for an economy/tow tune.. and this one has 300k but seems to have been takin care of 2 owner stock truck so dont wanna put much power to a 300k mile engine
Old Nov 21, 2013 | 03:35 PM
TS is as good as any. Just remember. No hot tunes when pulling. Creates very high egt and will burn it up
Old Nov 21, 2013 | 03:36 PM
That1Guy's Avatar
Yea and no ic on this truck are they bad about egts pulling trailers?
Old Nov 21, 2013 | 03:57 PM
joebob3093's Avatar
Moderator
Not really, get yourself turbo back exhaust, intake, gauges and a custom tuned chip and be done with it. That setup will run forever and be very reliable. No need for studs or gaskets with that.
Old Nov 21, 2013 | 04:01 PM
Should only need studs and gaskets for high horse and high boost. Custom tunes are pricey....but worth the cost if you want to run the truck for a long time
Old Nov 21, 2013 | 04:04 PM
joebob3093's Avatar
Moderator
Only need studs for 40+ psi, most guys will never see that. Custom tunes for a 7.3 are not that much. You can get a brand new chip with custom tunes for about 400.
Old Nov 21, 2013 | 06:10 PM
That1Guy's Avatar
Sounds good! Thanks
MMMichael
10
Feb 6, 2015 08:14 PM
