Best turbo and injector upgrade
Old Nov 19, 2013 | 06:04 AM
Cummin104's Avatar
Default Best turbo and injector upgrade
What's the best bang for your buck? What's your suggestions?
Old Nov 19, 2013 | 09:50 AM
lukesdiesel's Avatar
How do you use your truck?
Luke
Old Nov 19, 2013 | 11:19 AM
Cummin104's Avatar
Recreational no towing the most is towing 4 wheelers and playing around....
Old Nov 19, 2013 | 12:39 PM
jigabop's Avatar
what kinda power are you looking for and how far are you willing to take supporting mods?
cause this can go anywhere from a small budget upgrade, to a very moderate upgrade that pushes the limits of the injection pump...
both can be very reliable if done right...
for example my setup is pushing the limits of my stock injection pump yet it is a daily driver and very reliable. but I have the supporting mods to make it reliable..
I can give you part numbers and specs for custom parts to get some of the supporting mods on a budget for far cheaper than any of the vendors can get you those supporting mods for, but it is still an added cost on top of just turbo's and injectors...
Old Nov 19, 2013 | 03:24 PM
Cummin104's Avatar
Well I'm not on a budget just wanna know some good upgrades for my truck.... Ordering the edge cts, got the S&b intake looking for more breathing options and bolt ons.... I like to do things once...
Old Nov 20, 2013 | 11:04 AM
jigabop's Avatar
upgrade your lift pump before anything..
depending on your goal hp will depend on size of lift pump
under 500hp can run a 95-100gph lift pump
over 500hp needs a 150gph lift pump and 1/2" fuel lines + 1/2" draw straw.
need gauges. 0-30psi fuel pressure
EGT
boost
trans temp (if automatic)
will need a built auto if it is an automatic...
or a upgraded clutch if manual.
then it comes down to how much hp you want...give me a range and know that around 600-650 is about the max you will get on a stock injection pump...
Old Nov 20, 2013 | 12:34 PM
Cummin104's Avatar
Well I bought the truck from a insurance auction I own a body shop the truck came with a air dog and stacks ... She runs good too... I'm working on the front end ... He ripped the guages out and the chip ....I plan on ordering the edge cts .... These insurance trucks are like surprises you don't know what to expect.... My truck is a 6 speed...
Old Nov 22, 2013 | 09:57 PM
Airborne101's Avatar
Im running a DPS 62/12/65 turbo and dps 3 piece manifold, and I have a Edge juice with attitude with integrity plus 100hp injectors and some other upgrades. Im happy with it
