Fuel Pin-Original Position Lost
Old Nov 18, 2013 | 02:28 PM
metriccar's Avatar
Default Fuel Pin-Original Position Lost
I know this is a "BOMBERS" website but I'm more concerned with keeping the truck on the road for a long time. I have no EGT Gauge and no intercooler.
So, I do not have the original position for the fuel pin. Should I just make it so it's like halfway in between? The shallow part towards the top (or bottom) and the deep part on the other side?
Or before I install the pump, have someone adjust it somehow to what should be the proper setting?
Old Nov 18, 2013 | 02:34 PM
novapat's Avatar
the only way to adjust it to factory is on a machine...
Old Nov 18, 2013 | 06:33 PM
dan123dbl's Avatar
The fuel pin will have as scratch mark in it where it has been sitting. You will be able to see it and face it towards the front of the engine.
Unless you're talking about the fuel screw then you just need to turn it in until it will start and back it off / in a turn if you want.
Old Nov 18, 2013 | 08:25 PM
metriccar's Avatar
No, it's the fuel pin I'm referring to. I'll take a look and see if I can match up any wear patterns. That would save me a few hundred. Thanks for your help guys.
Old Nov 18, 2013 | 08:28 PM
dan123dbl's Avatar
You'll be able to notice an apparent wear mark in it. And you wouldn't be able to get too hot egt-wise with a stock engine anyways I don't think you have to worry about which way it is facing. With my mods I can barely get to 1250F, I have to let off because I'm going too fast.
Old Nov 19, 2013 | 12:38 AM
novapat's Avatar
oh im sorry I thought he was talking about the full power screw....my bad!!
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
