06 powerstroke
Old Nov 18, 2013 | 06:31 AM
shaver1979's Avatar
Default 06 powerstroke
Hey guys, I'm looking at buying a 2006 king ranch 4x4 powerstroke for work. I only haul materials from job to job, I do not pull anything. The reason I am looking at buying a diesel is because they seem to last longer than gas motors. I currently drive around 200 or more miles a day and I average around 50,000 miles a year. I'm looking at Ford because that's what I drive currently and Ford is all I've owned my whole life. I'm just wondering since I'm not pulling anything with it, will I still need to bullet proof it and change the oil cooler?
Old Nov 18, 2013 | 07:00 AM
HeavyAssault's Avatar
Bulletproof: You might be able to get by without it. Plenty of work trucks out there not BPd
Change the oil cooler: I'd expect to do this at least once. You need to check the EOT/ECT split to verify the current condition of the oil cooler.
Old Nov 18, 2013 | 10:13 AM
bkmac's Avatar
I have a 2006 F350 Crew Cab 4x4 that I use to pull a 8 horse trailer in the mountains of Montana and used to haul a 28' goose neck hauling hotshot freight.
The truck has 201,000 miles on it. At 99,100 the high pressure oil went - truck was covered under warranty so that was replaced. Besides that and a K&N air system and a Sinister coolant filter the truck is OEM.
I change the oil on schedule and use only OEM filters and Rotella T-6 oil.
Lately it has started running rough on start up and runs rough until it warmed up. At first I thought it might be an injector problem. Used Auto Enginuity and took the time to shut off each injector. Once I would shut one off the truck would run like crap - turn it back on and the truck smoothed out. Based on this I ruled out the injectors - took it for a test drive hooked up to Auto Enginuity and discovered my FICM would drop down to 44 volts so now I am thinking that is the cause of the problem.
Except for these problems the truck runs great and is not bullet proofed.
I have some major traveling to do next summer so I have contacted a couple of shops. For 15K I can re-motor the truck with a brand new engine with a two year unlimited mileage warranty. A lot of $$ but still a hell of a lot cheaper than a new truck!
Old Nov 18, 2013 | 06:34 PM
shaver1979's Avatar
Guys I really appreciate the info, it will help me a lot, I'm a Ford guy and I'll be a Ford guy till the day I die. Right now I drive a 2005 f150 fx4 with the 5.4L triton and I have 218,000 miles and I've done nothing but routine maintenance to it, still drives great! It just blows knowing that the truck I want needs things done to it right away so it can last a long time, but I think if I buy it and do those things I'll easily get 400,000 miles or more ya think?
Old Nov 18, 2013 | 07:17 PM
Adrenaline junkie's Avatar
Sounds like a good plan to me!
Old Nov 18, 2013 | 07:18 PM
bkmac's Avatar
Prior to going to PSD Ford I had a 96 F250 4x4 with a 5 sp & 460 cu in with 4:10s. That had 298,000 miles when I sold it and it never had a valve cover off. Great truck!!
makuloco2000
Dec 20, 2015 11:19 PM
Lsugod85
Jun 20, 2015 05:14 PM
makuloco2000
Feb 15, 2015 02:31 PM
leaderbeanjr
For Sale
Jan 20, 2015 01:22 PM
southernbelle14
6.0L Performance
Dec 29, 2014 10:53 AM
