Sensor Help
Old Apr 14, 2008 | 12:27 AM
Monster Truck's Avatar
Default Sensor Help
What does the Tach read off of? and does anybody have the part # for the APPS on the 99?
Old Apr 14, 2008 | 12:58 AM
Uncle Bubba's Avatar
This is what my manual shows.
24Valve APPS
Cummins- 3937161
Dodge- 4874412
Old Apr 14, 2008 | 11:32 AM
Ok thanks for the numbers on the APPS. Anybody know where the tach gets the rpm from? cam position sensor or something?
Old Apr 14, 2008 | 11:37 AM
On a 99 - tach signal comes from the crank position sensor
Old Apr 14, 2008 | 06:06 PM
Do you happen to have the part number for the cam position sensor?
Old Apr 14, 2008 | 08:19 PM
This is for 24V's:
1998.5 - 2000 had the crank position sensor - p/n: 4921601
2000 - 2002 used the cam position sensor - p/n: 4921597
Also, Cummins Quickserve online is here: https://qsol2.cummins.com/info/index.html
Old Apr 14, 2008 | 09:51 PM
are these cummins numbers?
Where is the cam sensor located?
Last edited by Monster Truck; Apr 14, 2008 at 09:51 PM. Reason: Automerged Doublepost
Old Apr 14, 2008 | 10:43 PM
Ummmm, did you even read my posts??....for the third time, a 99 has a Crank Position sensor. (Assuming you are asking about a 99 since you are posting in the 24V forum - if you are asking about your 12V - the p/n is the same as a 99).
Yes, its a Cummins part
Old Apr 15, 2008 | 10:22 AM
Umm your not really makeing any sense there boss, I asked where it was located not if it has one.
I thought it was ok to ask questions but I guess not. Didnt mean to upset you.
Old Apr 15, 2008 | 11:29 AM
Im not upset but you keep asking about a cam sensor after I told you 3 times that its a crank sensor on the early 24V - thers a difference isnt there?
