Whats needed when changing injectors?
Old Nov 17, 2013 | 09:29 PM
Stroker815's Avatar
Default Whats needed when changing injectors?
Starting a new project and need some advice. My injectors went bad so ive pulled them and im sending them out and ordering some warren 155cc's. My question is will i need any new gaskets or seals when putting everything back together? And is my truck gonna smoke any with these injectors? I run a SCT now and have egr delete. Im not looking to blow smoke just curious if it will. Thanks in advance
Old Nov 18, 2013 | 03:35 AM
97cummins's Avatar
I think with 155cc injectors your truck might smoke a little more because of the size of them.
As for the gaskets, I think you can just replace the gaskets for the valve cover gaskets and for the injectors.
Old Nov 18, 2013 | 05:43 PM
bobfbigman's Avatar
As far as the valve cover gaskets, they are reusable and only need replacing if cracked, the injectors should come with the Orings and seals
Old Nov 18, 2013 | 06:41 PM
Stroker815's Avatar
ok that dont sound bad then. As long as it smokes because of power instead of bad tuning. haha but thats what i thought on the gaskets. I knew ford made reusable transmission pan gasket and it felt about the same. Thanks yall
Old Nov 18, 2013 | 07:16 PM
Adrenaline junkie's Avatar
I would check the harness to the injectors while you are in there. look for cracks in the insulation especially on bends. cover gaskets are reusable if not damaged. make sure you get the copper seals right and one per cyl. Let us know what you think of the 155 injectors and what tune you are running with them!
Renteria1217
19
Oct 13, 2015 01:36 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
