mpg difference between 6 speed and 5 speed
Old Nov 17, 2013 | 06:01 PM
truckgal's Avatar
Default mpg difference between 6 speed and 5 speed
I was wondering what the mpg difference is between a 2001 5 speed and a 2001 6 speed.
Old Nov 18, 2013 | 12:19 PM
jigabop's Avatar
little to no difference.
final drive ratios are very close .75 in the 5-spd .73 in the 6-spd.
6-spd has closer shift points and less rpm drop that helps with towing..
rear end ratio (3.55 or 4.10) and what you do with the truck will have more of an effect on fuel economy than what trans is in it...
Old Nov 20, 2013 | 10:35 PM
Pokechop's Avatar
I agree. It depends on how you drive the truck. My overhead computer shows my average at about 16.7mpgs... but I have RV275 injectors, Banks High Ram, Fleetguard AH19037 BHAF, and a larger exhaust.
If I keep my foot out of it on the flats I can see numbers between 19 and 22, and I'm running the NV5600 6 speed.
Old Nov 21, 2013 | 10:51 AM
jigabop's Avatar
I get 15.5MPG at best with my mods, but when it was stock it got 17.5 at best...
4.10s are hell on fuel economy...my 35" tires aren't helping either... but they do help keep me from redlining on the freeway.
Old Nov 21, 2013 | 02:44 PM
moparisthebest's Avatar
Originally I assumed a manual would get better fuel mileage too, but when you look at the final gear ratios, overdrive on an automatic is actually the best of all available transmissions at 0.69.
I got my info from here, which has handy diagrams of all ratios for all transmissions with all rear-end ratios:
Gear Vendors Under/Overdrive Dodge/Dodge RAM Final Drive Ratios.
Old Dec 28, 2013 | 03:48 AM
White 99 Dodge's Avatar
I've got a programmer on mine and get around 21mpg with the 5spd
Old Dec 28, 2013 | 06:44 AM
tbirdz24v's Avatar
With my mods I get about 17 in the city and I've hit 24 on the highway. As long as I stay out of the skinny pedal I'm good. I'm running the nv5600 with 3:55 rears.
Old Jan 4, 2014 | 08:32 AM
Precision's Avatar
I have read this before and found it interesting. But I do not get better mpg with my auto. My thoughts are that the torque converter allows for too much power inefficiency while getting up to speed that it kills potential mpg. Stock TC has like 65% efficiency - pretty lame IMO.
My 2000 has a 5 speed with all the right mods for mpg and my calibrated scangaugeii says I get around 26-27mpg on the highway when I keep speeds at 58 in 4th gear.
Old Jan 4, 2014 | 05:37 PM
tiremann9669's Avatar
I get 32 mpg's with mine
cjt8569
Sep 29, 2015 06:39 PM
Dertyd
24
Jun 7, 2015 02:45 PM
May 17, 2015 12:10 PM
F250MACH
Apr 26, 2015 05:19 PM
