2004.5 died now wont start no codes
Old Nov 12, 2013 | 06:17 PM
jeremypreslar's Avatar
Default 2004.5 died now wont start no codes
yesterday i started my truck pulled forward about 20 feet then my truck died and wont start back up the only code i am getting is a p1757 im assuming that being a solenoid in the tranny has nothing to do with this not starting problem i have cleaned all the battery connections and am going to make sure the batteries are fully charged tomorrow it seems like its not getting fuel but i just changed the fuel filter and i would think the fuel pump would throw a code if it were bad any suggestions are appreciated
Old Nov 12, 2013 | 06:48 PM
kcmotorz's Avatar
I am having relatively the same issue, Could be your lift pump or injection pump. Also most mechanical failures don't set the accurate codes if any on these cummins set ups.
Old Nov 12, 2013 | 10:41 PM
i was thinking fuel pump but im not sure wasnt any signs of it going, no loss of performance or stuttering.Im not sure about this pump on my old gasser when the pump went i was able to bump the tank and get it going again as a temporary fix, the night before it happened i did accidentally leave the key on for a few hours maybe the subs sucked the batteries down? I hope its not the pump but at this point im starting to think it is
Old Nov 13, 2013 | 12:11 PM
kcmotorz's Avatar
A quick way to tell is put a pan under the drain hose for the filter resevoir, open the drain and remove the fuel filter. Leave it open and and turn the key on, if the housing fills with diesel your lift pump is good, if it doesn't I'd start there.
Old Nov 13, 2013 | 09:52 PM
any ideas of a fuel pump relay location?
fixed cleaned battery terminals till they shined replaced fuel filter put on a charger for a few hours and started right up
Last edited by jeremypreslar; Nov 13, 2013 at 09:52 PM. Reason: Automerged Doublepost
Old Nov 30, 2013 | 08:54 AM
coxey2's Avatar
Default fixed yet?
Mine died and won't start now. Same symptoms as yours. Figured it out yet? thanks
Old Nov 30, 2013 | 10:51 AM
kcmotorz's Avatar
no not yet, put a new lift pump in same issue, gonna try testing injectors next.
Old Dec 2, 2013 | 07:19 PM
keepitreal's Avatar
before you test the injectors make sure the crossover tubes are to the correct torque spec of 37ftlb. I think sounds about right. that solved my problem after months of fighting a no start issue on an 03.
Old Dec 2, 2013 | 08:08 PM
1999stroker's Avatar
41lbs
Sent from my DROID BIONIC using Tapatalk
moose2j
Jun 21, 2015 12:36 AM
ronstop
Feb 26, 2015 09:48 AM
RayRay4991
Feb 23, 2015 07:45 AM
southernbelle14
6.0L Performance
Dec 29, 2014 10:53 AM
Tyler_302
Oct 22, 2014 07:08 PM
