Low Power
Old Apr 13, 2008 | 05:22 PM
torquey's Avatar
Default Low Power
i installed my new apps, cleared the codes, and reset my throttle.now it seems my truck doesant have the same power as before.i did have a local dealer put in a code to change my torque managment but i noticed no change due to the bad apps, any ideas?
Old Apr 13, 2008 | 07:09 PM
Uncle Bubba's Avatar
Is the new APPS set so that the voltage matches the tag on the bottom of it now that it's installed.
Old Apr 14, 2008 | 10:38 AM
torquey's Avatar
i'll have to get the exact # but i know the voltage on the new apps is higher than the old one. i know its over 600 and the old one was like 594, do i need to adjust the new and how?
Old Apr 14, 2008 | 10:51 AM
Nitelord's Avatar
Check out this Post. It explains all you need to do.
https://www.dieselbombers.com/24-val...ode-p0122.html
Old Apr 14, 2008 | 01:33 PM
The new one should have it's own number on it that it will have to be set to. In theory it should have come pre-set to it but we all know how that works.
Post number 5 in this link may also help out if you still need more info after Nightlords posting.https://www.dieselbombers.com/24-val...tomy-apps.html
fivepointohno
5.9L CR Performance
12
Jan 25, 2016 01:07 PM
robbyS
Apr 16, 2015 02:22 PM
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
