6.0 hard start when cold fires rite up when plugged in
Old Nov 12, 2013 | 11:50 AM
aimstarllc's Avatar
Default 6.0 hard start when cold fires rite up when plugged in
Hello all. I have a customer f350 service truck 04 with 6.0. Long story short truck hard to cold takes about 5 to 10 min to start. Have snap on solus so I can see live data. When cranking everything checks out Ipc volts are correct Ipc psi is over 1000 when cranking ipr volts correct an ipr% 59 when cranking. Ficm also checks out at 48volts when cranking. So I that's where I'm at an need to know where to go from here. When cranking I can't see any smoke at all which makes think injectors aren't firing. But like I said if I plug it in it fires rite up runs a little rough then fine the rest of the day. Oh yeah truck has 203000 on the miles. Any help greatly appreciated thanks.
Old Nov 12, 2013 | 07:14 PM
kcmotorz's Avatar
Sounds Like a glow plug or vc harness issue to me, I had a loose valve cover harness on two banks and had an issue with starting at any temp, once it was warmed up no issue but cold starts was terrible. I ordered motorcraft valve cover gaskets and injector/ glow plug harness's just to be safe for both sides and no issue after that.
Old Nov 27, 2013 | 12:05 AM
LukeCrawford's Avatar
maybe you should try the glow plugs
Old Nov 29, 2013 | 09:23 AM
tenwheeljoe's Avatar
I had the same problem, changed to synthetic oil. Starts now at 20 degrees without being plugged in. Just a suggestion.(03 6.0)
Old Nov 29, 2013 | 07:04 PM
Adrenaline junkie's Avatar
5-40 Rotella synthetic for me! Works all winter, no plugging in. Even at one -2 degree day. . .. . Seems to work and cheap fix if it solves ur problem. .
Old Dec 6, 2013 | 07:19 AM
aimstarllc's Avatar
Thanks for everyones input we found problem it was a short in injector wire harness ordered new harness an she fired rite up
Old Dec 6, 2013 | 01:07 PM
Sweet. . . They are fun when they run!
Cavnar
Sep 9, 2015 07:18 PM
dfish001
Mar 30, 2015 03:07 PM
dandbmcc
Mar 14, 2015 11:05 PM
ronstop
Feb 26, 2015 09:48 AM
custom7.3
Nov 23, 2014 10:44 PM
