99 2500 Cummins MPG low?
Old Nov 11, 2013 | 05:31 PM
kedlin88's Avatar
Default 99 2500 Cummins MPG low?
I just bought a 1999 Dodge Ram 2500 Cummins, EXT Cab, Long bed, 266,500 miles, Automatic, 4x4. It has 4" straight pipe, Airdog 150 pump, and a BHAF. Other then that's it completely stock.
After I got it I did all the fluid/filter changes. I have finally gone through 3/4 tank of diesel and I calculated my mileage and It only came out to 13.1 mpg.
Would this be about right for my truck? There's no codes, and I did try really hard to drive it easy, but every now and then the pedal does get away from me.
Thanks,
Old Nov 11, 2013 | 06:28 PM
lauber_03's Avatar
seems low to me, when mine was stock minus the lift pump i was getting a little over 17. maybe needs valves adjusted. is it really chatty sounding?
Mopar1973Man's Dodge Cummins Articles - Valve Lash Adjustment
Old Nov 11, 2013 | 06:42 PM
kedlin88's Avatar
Kinda sounds chatty. I will adjust the valves this weekend. Being out of spec will cause that much of a mpg drop?
Thanks,
Old Nov 11, 2013 | 10:05 PM
tbirdz24v's Avatar
What's your rear end gears? And are you running highways or back roads?
Old Nov 12, 2013 | 01:25 PM
jigabop's Avatar
and what tire size?
is it cold were you are?
winter mileage will be a few mpg lower than summer mileage in a 24v cummins. they use more fuel and retard timing to compensate for colder climate conditions.
Old Nov 12, 2013 | 08:14 PM
chuffysplace's Avatar
wouldn't hurt to verify air pressure is ok in the tires and that you don't' have a dragging or sticky brake caliper(s). I would think you should be around 17 at least.
Old Nov 17, 2013 | 03:16 AM
AlaskaCummins's Avatar
I run with 295/70/17 tires, winter, 3.73 gear, all town driving in a 6spd without a programer or tuner and get 11-13 MPG. This is probably due to the fact I drive a little fast, always have 1/2 ton of heating oil in my bed, and have a late 02' without the CAD, so it is always spinning my front axles. When I'm running highway at 55, getting about 16MPG. So it has a lot to do with your driving habits, speeds, and tires.
There is a lot of great ways to increase your milage. Airbox, free flowing exhaust, programer, injectors, tires, free spin hub kits, WaterMeth/Propane, tropper/tanneau cover, and if you do a LOT of interstate driving (75+mpg) a Gearvendor Overdrive unit.
robbyS
Apr 16, 2015 02:22 PM
big willy
Diesel Engine Conversions
Feb 24, 2015 09:12 AM
Omingnome
Oct 20, 2014 12:25 PM
dieseldude03
For Sale
Oct 2, 2014 07:53 AM
