Long Cold Start
Old Nov 11, 2013 | 02:41 PM
Curry's Avatar
Default Long Cold Start
Well just recently when the out side temps got into the 30-40s its been taking longer to start. The other day it took a solid 5-8 seconds of then a big puff of white then black smoke. No rough idle or strange noises. Also have a little bit of coolant lost looked like some was dripping from the drain plug on my radiator. Any ideas?
Old Nov 11, 2013 | 06:01 PM
Adrenaline junkie's Avatar
Do you have an oil pressure gauge in truck? A high pressure leak may cause longer starts.
Old Dec 31, 2013 | 02:07 PM
Curry's Avatar
Been kinda busy but here is whats happened so far. By buddy that works at ford came over with the computer after letting the truck sit for a few days and completely cold. Only thing that showed up was 4 or 5 bad glow plugs so we just changed all of them and let it sit again till a cold morning to start. Took a long time to crank but fired right up no problems ran fine. So we are thinking the GPCM is bad?
Old Dec 31, 2013 | 08:34 PM
Are you getting some white wispy smoke at crank? I just had to do my GPCM last week. .. All better now!
Old Jan 1, 2014 | 11:01 AM
Curry's Avatar
A little bit of white smoke then turns to grey/black. Had a long start again this morning after I put the new GPCM in. Not sure what else it could be
Bigredpowerstroke
Aug 14, 2015 10:31 AM
Mike0885
May 27, 2015 12:07 PM
dandbmcc
Mar 14, 2015 11:05 PM
ronstop
Feb 26, 2015 09:48 AM
custom7.3
Nov 23, 2014 10:44 PM
