Stock Tranny
Old Nov 11, 2013 | 12:32 PM
JakeAdkins's Avatar
Default Stock Tranny
I recently bought a cummins and im just wondering how much it is gonna take to screw up my tranny? I dont drive it hard. I have the edge EZ in it right now.
Old Nov 11, 2013 | 01:39 PM
better_off_witha_diesel12's Avatar
Im guessing its a auto so not much... i think with a manule youd be safe for a while
Old Nov 12, 2013 | 06:55 PM
kcmotorz's Avatar
I had an edge programmer on my old 7.3 PS and it did some damage, rough tunes. I switch to a TPS 6 position and it was awesome. I have a manual trans in my cummins but I have heard modded auto's can take a beating ... for a little while.
Old Nov 14, 2013 | 07:27 AM
ramrod5.9's Avatar
Is your tranny the stock one? Manuel or auto? My 06 has 145k and had a edge j/a most of its life with the stock auto tranny (which is on its way out). Keep the band's adjusted in them to make it last a tad bit longer.
Old Dec 1, 2013 | 05:08 PM
mykaos's Avatar
If auto: keep bands adjusted, fluid (synthetic only) changed not flushed, bump up the line pressure (research like I had to, the "how to" is out there), gut the pos converter anti drain back valve, you will be amazed at how durable these 48RE's are (speaking from experience).
Old Dec 2, 2013 | 04:22 AM
CSC5150's Avatar
I've read approximately 450hp and 750tq is the limit on a stock 48re.
Old Dec 2, 2013 | 08:50 AM
Dynamic's Avatar
If your transmission is healthy (clutch packs and intermediate band), you can put in a good triple disc converter and a properly built and calibrated valve body and buy yourself some time and pick up some performance. I would also put in a Sonnax billet accumulator piston and billet intermediate servo cover while I was doing the valve body.
But, your input shaft/direct hub is still going to be a weak spot, along with a stock band that is nothing to write home about...
Old Dec 8, 2013 | 07:09 PM
FlyingDutcman's Avatar
dieselpowa
5.9L 12V Performance
Sep 12, 2015 05:28 AM
wannadrag
May 25, 2015 03:07 PM
wilki
Feb 12, 2015 09:04 AM
Ol' RED!
Dec 11, 2014 10:00 AM
Trevlar11
Nov 16, 2014 01:59 PM
