starting problem
Old Nov 7, 2013 | 05:14 PM
pgaglian's Avatar
Default starting problem
truck will not start. At stater motor relay #1 from stater control output only has 11 volts, if I take a jumper and jump from #4 to the battery starts right up. I"m assuming that where ever power comes from to #1 voltage is to low. Any ideas guys?
Old Nov 7, 2013 | 06:47 PM
Gotta<3a12valve's Avatar
Push button
Old Nov 8, 2013 | 09:01 AM
dangerous1965's Avatar
Be careful jumping anything in the fuse box It's a lot of cash and easy to destroy! TIPM= Dodge junk power control system! I assume the batteries are fully charged and all the terminals have been cleaned?! 11 volts is low for battery output the relay only lets the available power thru! Can you clarify no start: Slow crank, nothing from key turn, or?
Old Nov 8, 2013 | 09:26 AM
pgaglian's Avatar
thank you for replying, batteries are at 12.4 and fuse box the same. Just the wire feeding starting relay at 11.1, I'm wondering if this wire is coming from the computer?
forgot to answer other question, starter relay just clicks no start at all not enough power for the hold-in at starter
Old Nov 9, 2013 | 01:02 PM
Yeah the computer controls the relay but 11 is enough to close it!? Pull the relay and check power voltage on the hot slot should be same as batteries. Check for a broken feed wire or a corroded BAdly feed wire somewhere it's not letting Amps thru! Either at the batteries or the starter.
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
hurriedcoyte
Jun 19, 2015 06:26 AM
Jmohr52
Nov 2, 2014 08:55 PM
