OverFlow Valve
Old Nov 7, 2013 | 12:47 PM
SRTcummins's Avatar
Default OverFlow Valve
Ok the overflow valve on the vp44. If I increase lift pump pressure to ~~18 psi wil I need to route a hose from the overflow to the tank. I am very confused on this people have all said no but then how does the fuel return to the tank if the overflow is opened?
Old Nov 7, 2013 | 04:08 PM
jigabop's Avatar
the vp44 has a return line from the factory...fuel the vp44 does not send through the injection lines to be burnt, gets returned via the overflow valve into the return fuel line that dumps back into your fuel basket in the tank.
in the image below, the black line on the left is my factory vp44 return line.
the line hooked to the black QC fitting is the airdog return line, and the line on the far right hooked via the brass/aluminum JIC fittings is the suction/supply line.
RA113024
Mar 13, 2016 07:42 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
behrendt1061
Dec 4, 2014 05:49 PM
woodsman27
Oct 26, 2014 02:13 AM
