Injector advice needed
Old Nov 7, 2013 | 10:13 AM
Texas Pride's Avatar
Default Injector advice needed
I have an 01 3500 with a 150gH fass pump and a quadzilla, next thing I would like to get is injectors, I don't really know just a whole lot about them, Its my daily driver, I pull big loads from time to time but id like to hot rod it too, id like to get the biggest I can get without hurting the longevity of my engine (already have 320,000 on it) so what would be the best set up for me. Also if I get hopped up injectors would I have to get head studs?
Old Nov 7, 2013 | 11:13 AM
jigabop's Avatar
with injectors comes supporting mods...
are you prepared to upgrade other things as well?
if you do all supporting mods necessary for the power you go with, then running large injectors won't hurt anything on your motor..
I'm running 6x.013's in mine and I daily drive it.
but I have the supporting mods for it as well which include:
compound twin turbo's
115# valve springs
HD push rods
double disc clutch
hd clutch hydraulics
150gph fuel system
gauges for both stages of the turbos
upgraded intercooler boots/clamps, etc...
all depends on how much power you want and twins or large single...
Old Nov 7, 2013 | 02:29 PM
I'm not looking for giant power gains because I am on a limited budget, im just looking to put a little more "get up and go" into it
Old Nov 7, 2013 | 04:00 PM
jigabop's Avatar
throw some 7x.010 SAC injectors in there and a boost elbow on your hx35...
oughta make it a lil more fun
Old Nov 7, 2013 | 04:26 PM
you'll have decode injector names like that, im used to calling them 50hp, 100hp, etc
Old Nov 8, 2013 | 01:15 PM
jigabop's Avatar
~150hp
7x.010 SAC would be the proper way of sizing it... you can't go by hp ratings because hp ratings are all BS.
7 hole .010 hole size. cylindrical blind or micro blind sac
151* spray angle and 300-310bar pop pressures would make them nice and super clean for that HO truck
Old Nov 11, 2013 | 01:33 PM
but is that big enough that I would have to stud it or get a new turbo
Old Nov 12, 2013 | 12:50 PM
jigabop's Avatar
studs are never a bad idea. more of a preventive measure to keep a head gasket from blowing or a head from warping.
being a HO truck, as long as you aren't running around with wiretap fueling cranked up, you can get away with 7x.010's with the stock turbo and a boost elbow on the turbo set to 35psi.
a mild turbo upgrade in the future wouldn't be a bad idea either if you plan on towing.
in other words keep your adrenaline set to lvl2 or lower and you will be fine....trust me those injectors will provide more than enough power that you won't even need to think about going to lvl3 or higher it will already put you firmly back in your seat with just the injectors. they make a huge improvement in performance...far more than the adrenaline did especially on a HO truck that has smaller injectors than SO trucks do stock...
Old Nov 12, 2013 | 01:06 PM
If I did that would I be better off just selling my quadzilla, I want my truck to be badass but on the flip side I can't do anything that can blow it up cause if I blow it up I'm screwed!
Old Nov 12, 2013 | 01:47 PM
jigabop's Avatar
keep the quad.
unplug the wiretap if you are worried about it .
you won't blow it up.
here is what I have in my truck and I DAILY DRIVE it
2000 RAM 2500 QCSB 4x4
6x.013 micro blind sac injectors (custom made by weston shupe)
S357 over S475 compound twin turbos (57/65/14 over 75/96/1.32AR)
crazy carls S300/S400 twin plumbing w/5" downpipe (I see 75psi boost from the twins)
ARP 2000 head studs @ 135lbs/ft
crower neon 115# valve springs
manton racing 3/8 dia, .095 wall, 11.45 OAL, 10mm ball/cup hard drawn push rods
south bend 3600-6 double disc clutch
south bend HD clutch hydraulics
trans-cool PTO coolers
vulcan performance intercooler boots and spring clamps
airdog150 fuelsystem (old style with JIC fittings and 1/2" line)
vulcan performance modified liberty fuel module w/draw straw 5
DiPricol 0-30psi mechanical fuel pressure gauge
isspro 0-60 and 0-100psi boost gauges
quadzilla adrenaline w/pulse v1
DAP 5" straight pipe exhaust
4th gen OEM steering conversion
Carli lo-mount bilstein 7100
steering gear brace
DT pro-fab 3rd gen style adjustable track bar
Posi-Lok cable
315/75R16 BFG mud terrain tires
4.10 gears D60 front D80 posi rear (stock)
late model NV5600 trans (1 3/8" input shaft....I broke and replaced my stock NV5600 with the 1 1/4" input shaft 3 years ago)
NP241DHD xfer case (stock)
SLT + Sport package
goose neck hitch
factory towing package
2" leveling kit
aftermarket 16" polished aluminum wheels
in-dash navigation
2 amps 1300w total
10" subwoofer
TIMBO APPS
amsoil in the engine, trans, and xfer case.
Smarty programmer for passing emissions with
MPG/hi-idle fooler switch (4 position switch available via DAP)
oh yeah, and it's a 53 block!
that's all the crap done to my truck off the top of my head and I drive it daily
all of that stuff was done to it over the past 5-6 years. wasn't built in a day. I'm not made of money
