Stumped on this 24 valve
Old Nov 5, 2013 | 11:16 AM
tonkatruckon44s's Avatar
Default Stumped on this 24 valve
This is the first cummins i am working on, i usually work on 6.5s but a guy needed me to try and diagnose this truck so here it goes.
I am working on an 02 2500 5.9 24valve 116,000 miles stock except cold air intake and 4 inch exhaust. so it does this more when it is cold then when its warm. I start it up let it idle for a few minutes, then i take off about 5 minutes down the road i loose all power, i shut it off it runs great it does this till it is up to full operating temp then it runs fine. It does not blow excessive black smoke no white or blue. I am at a loss of where to start. No light but if i read codes it comes up p0216. i am going to try to clear it after work see what it does. I've read it could be as simple as a sensor to as complicated as an injection pump. Also its not that it runs bad when it looses power it is just that it doesnt get up and go at all.
Thanks for the help in advance.
Old Nov 5, 2013 | 11:25 AM
lauber_03's Avatar
more then likely the injection pump is bad. upgrade lift pump and new ip and you should be golden.
Old Nov 5, 2013 | 11:27 AM
jigabop's Avatar
P0216 = timing control circuit malfunction.
that is one of the vp44 death codes.
what is fuel pressure like on this truck?
monitoring fuel pressure is critical on 2nd gen 24v cummins engines as they are VERY sensitive to it.
these things should have come stock with a 0-30psi fuel pressure gauge. I highly suggest hooking up a fuel pressure gauge to it and checking fuel pressure. if it goes under 10psi in any conditions other than engine off... then the lift pump needs replaced and/or fuel filter.
should hold over 10psi at ALL times. this means wide open throttle, cruising, and idle. over 14psi under all conditions would be ideal as it keeps the overflow valve open to have fuel constantly cycling through the vp44 to help cool it.
typically a P0216 is caused by the electronics in the vp44 overheating and causing electronic failure which I am sure you are familiar with since you know your way around a 6.5L chevy diesel which is notorious for electronics failure due to overheating. though the 6.5L can separate the electronics from their injection pumps... the vp44 can't and is not a serviceable part. if the electronics go in the vp44, the whole pump needs replaced. so your best chance at keeping it alive is keeping constant fuel flow through it so it stays cool.
I run 20psi fuel pressure at idle, 18psi cruising, and 16psi @ WOT
check that fuel pressure and address it if it is too low then post back.
Old Nov 5, 2013 | 12:35 PM
So it is possible for it to be something other than the IP i will test fuel lift pump when i get home this evening
Old Nov 5, 2013 | 08:01 PM
Rooster24v's Avatar
I think Jigabop is right.. the VP44 needs at minimum 8-9 psi while running. if even at one time it drops below that.. its more than likely your VP will be done for.
I hear "taps" playing in the background...
Old Nov 6, 2013 | 09:18 AM
Fuel pressure is correct it has the lift pump in the tank I dont know if that is better than the frame rail or if it is not. The think is if i let it warm up for ten minutes, shut it down and immediately restart it it runs flawlessly, but if i try taking off without shutting it down its low on power. For instance i let it warm up this morning and shut it down then drove to work i didnt have any symptoms the rest of the way. But the day before i let it run for 2 minutes instead of 10 and jsut got in and drove to work i had to restart it 4 times till it was up to operating temp then it dove flawlessly the rest of the way.
I mean Fuel pressure is 15 when at idle and it has 10 at WOT
Last edited by tonkatruckon44s; Nov 6, 2013 at 09:18 AM. Reason: Automerged Doublepost
Old Nov 6, 2013 | 11:03 AM
jigabop's Avatar
sounds like the vp44 is on borrowed time.
start saving up...
$1k in parts alone to replace it.
10psi is technically adequate pressure, however I wouldn't even drive my truck if it dipped down that low in pressure.
Old Nov 6, 2013 | 11:37 AM
Bryce's Avatar
You could try this https://www.dieselbombers.com/98-5-0...ronic-fix.html Its no guarantee but it could save you some money
Old Nov 6, 2013 | 03:14 PM
05RAM2500's Avatar
a grand... wholly moly
Old Nov 7, 2013 | 04:41 PM
Cleaned then connection on the IP and it seems like It fixed it but i think the injection pump is on borrowed time it is the original pump and lift pump with 116000 and i just got the okay from the dealership to get a new FASS lift pump and Industrial Injection IP that is the next project,
